What model "Battery Tender" do you have? #1334421
11/12/12 08:19 PM
11/12/12 08:19 PM
GMP440 Offline OP
GMP440  Offline OP
Wanted to ask those on the board , what model battery tender are you using? There's five or six models of them.
Re: What model "Battery Tender" do you have? [Re: GMP440] #1334422
11/12/12 08:25 PM
11/12/12 08:25 PM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
I just bought 2 juniors, they were cheap and seemed to work the same. Time will tell on how well they work.
Scott
Re: What model "Battery Tender" do you have? [Re: GMP440] #1334423
11/12/12 08:51 PM
11/12/12 08:51 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Re: What model "Battery Tender" do you have? [Re: Exit1965] #1334424
11/12/12 10:26 PM
11/12/12 10:26 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I was using the Black & Decker ones, but they don't last very long. A few years ago I bought a few Schumacher tenders, and they've been reliable.
Re: What model "Battery Tender" do you have? [Re: topside] #1334425
11/12/12 11:26 PM
11/12/12 11:26 PM
St.Louis,Mo.
70RR383 Offline
70RR383  Offline
St.Louis,Mo.
Bought a battery minder the first time from northern tool.Then I just bought a tender Jr off amazon for under 26.00 to my door.Both are the small wall charger ones.The older one works great so I am hoping this new one works as well.They do a cleanup every once in a while and monitor the battery.
Re: What model "Battery Tender" do you have? [Re: GMP440] #1334426
11/13/12 01:10 AM
11/13/12 01:10 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
My preference is the Deltran Battery Tender Jr, been using (2) for a couple of years. No problems works exactly as promised...
Just my $0.02...
Re: What model "Battery Tender" do you have? [Re: Sinitro] #1334427
11/13/12 01:57 PM
11/13/12 01:57 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Been using a solar charger for quite awhile now. It must work awful well 'cause out of 5 batteries that get rotated on it they all fire the cars up no problem. Two of them are over 10 years old too.
Costs ya nothin' to run it as well.
Mo' Farts
Moderated by "tbagger".
Re: What model "Battery Tender" do you have? [Re: Grizzly] #1334428
11/13/12 03:17 PM
11/13/12 03:17 PM
OWL
Culvers Offline
Culvers  Offline
OWL
Culvers
Re: What model "Battery Tender" do you have? [Re: Culvers] #1334429
11/13/12 04:11 PM
11/13/12 04:11 PM
Northeast
edl Offline
edl  Offline
Northeast
Re: What model "Battery Tender" do you have? [Re: edl] #1334430
11/14/12 06:44 AM
11/14/12 06:44 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I have a Harley one.My kid was a tech at the dealer and I got it for like 40 bucks or so.Its at least 14 years old.Bought it for my Ultra and use it on it and my 58 HD and my go kart and the other 2 HDs.Ill even put it on the tractor.Best $$ I spent.Rocky
Chrysler Firepower
Re: What model "Battery Tender" do you have? [Re: therocks] #1334431
11/14/12 08:53 AM
11/14/12 08:53 AM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I've got an Auto Meter Battery Extender.
Works great. This one anyway. I had two previous ones replaced under warranty. I've probably had this last one for more than five years.
They have very little charging capacity, so if you have a deeply discharged battery, you'll need a real charger to bring the volts up. If the voltage is too low, it trips out (which may have been what killed my first two units).
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: What model "Battery Tender" do you have? [Re: 471Magnum] #1334432
11/14/12 09:32 AM
11/14/12 09:32 AM
NY NY
3
340duster340 Offline
NY NY
I have the 4 bank battery tender with the optional long cables. Its nice because it takes up no space (wall mounted) and can reach all the junk I have in the garage.
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: What model "Battery Tender" do you have? [Re: 340duster340] #1334433
11/14/12 11:52 AM
11/14/12 11:52 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Two reproduction batteries in 20yrs,never needed one,usually started once a month through the winter unless I forgot,never had a problem!
Re: What model "Battery Tender" do you have? [Re: GMP440] #1334434
11/14/12 12:26 PM
11/14/12 12:26 PM
Frederick, MD
71charger Offline
71charger  Offline
Frederick, MD
I bought a Plus and was so happy with it, I bought a 2-bank charger.
Re: What model "Battery Tender" do you have? [Re: Sinitro] #1334435
11/14/12 03:07 PM
11/14/12 03:07 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Just my $0.02...
Ive got 2 for my harleys, and I have a red top in the Demon and dont need to tend it ever, even if it sits all winter without starting up, now im sure Ill need one since I just typed that. But I have the same ones you have in the picture and they are fine, I have a peak brand from menards also, but its on the lawn mower.
Re: What model "Battery Tender" do you have? [Re: Sinitro] #1334436
11/14/12 10:46 PM
11/14/12 10:46 PM
S.I. N.Y.
1MYTGTX Offline
1MYTGTX  Offline
S.I. N.Y.
Just my $0.02...
I have been using the same for 5+ years now....
1MYTGTX
Re: What model "Battery Tender" do you have? [Re: 1MYTGTX] #1334437
11/15/12 12:45 AM
11/15/12 12:45 AM
Cincinnati,Ohio
jcastle1 Offline
jcastle1  Offline
Cincinnati,Ohio
Deltran battery tender jr. since 1995. Same battery as well....
