Limits of 2.5" H-Pipe Duals.... #1334086
11/11/12 11:00 PM
11/11/12 11:00 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
What sort of power will a typical muffler shop 2.5" dual exhaust support with an H-pipe?
I'm just trying to see if a motor capable of 600-800hp will lose a ton of power, or if it does lose some power, will it just be really quiet in comparison to a 3" dual?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Limits of 2.5" H-Pipe Duals.... [Re: AlexP] #1334087
11/11/12 11:50 PM
11/11/12 11:50 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
Go with 3" if you are looking for upwards of 800hp
Re: Limits of 2.5" H-Pipe Duals.... [Re: AlexP] #1334088
11/11/12 11:50 PM
11/11/12 11:50 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
The F.A.S.T. cars are limited to a 2.5 exhaust, it does not seem to be too much of a hindrance for them.
Getting old just means you were smarter than some and luckier than others.
Re: Limits of 2.5" H-Pipe Duals.... [Re: dannysbee] #1334089
11/12/12 12:02 AM
11/12/12 12:02 AM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I disagree...it is a hindrance...they would just make even more power with properly sized exhaust. They do make it work....but it's still a compromise.
Re: Limits of 2.5" H-Pipe Duals.... [Re: Defbob] #1334090
11/12/12 01:12 AM
11/12/12 01:12 AM
My old 440 powwered 1969 Dart picked up from 12.23 at 109.5 MPH to 11.39 at 117.7 MPH by removing the old 2.5 inch inlet and outlet turbo muffs with 2.5 inch pipes coming out of the Hooker A body fenderwell headers with side pipes exiting in front of the rear tires My Duster has three inch pipes from the same headers straight back to a set of 3 inch in and out 14x7 Mganflow muffs mounted at the rear bumper, this car picks up .04 and 1/10 MPH in the 1/8 mile by removing the entire exhaust sytem. The increase in performance is probally do to the weight differences
Re: Limits of 2.5" H-Pipe Duals.... [Re: Cab_Burge] #1334091
11/12/12 01:05 PM
11/12/12 01:05 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'll just have to run it as-is for now. Hopefully it will lose a little bit of power and still stay sorta quiet.
It's a cent blown 3g Hemi...
