Mopar Performance Distsibutor Oil Leak? #1333925
11/11/12 04:17 PM
11/11/12 04:17 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hi Guys. Last fall I converted my car to electronic ignition. I put a Mopar Performance Kit in it. I have not put many miles on the car since I made the change. Yesterday I took the car out and put about 100 miles on it. I looked under it this morning and there was a puddle of oil on the ground. There was oil around the distributor so I thought it was the O ring seal at the base. I pulled it and found oil inside the distributor running out the little holes in the bottom. Have any of you ever had this problem? Is there a shaft seal on it? How do I replace it? Any help would be greatly appriciated.
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: Mopar Performance Distsibutor Oil Leak? [Re: ScottG] #1333926
11/11/12 08:22 PM
11/11/12 08:22 PM
No shaft seal. I would drive out the lower roll pin & remove the plastic collar & add 1/2" ID shims (locally or www.speedwaymotors.com has a kit of em for $5) to reduce the axial play to .005". Other candidates are excessive bushings/shaft radial play but you said it's pretty new, excessive blowby/clogged/wrong PCV
Re: Mopar Performance Distsibutor Oil Leak? [Re: RapidRobert] #1333927
11/12/12 10:07 PM
11/12/12 10:07 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Well I think I found the problem. I put a set of new chrome valve covers on last fall as well. I checked the air breather that came with the covers. Inside it looked like an electrical knock out that was not completely knocked out. It only had about a 1/4 inch sliver that was open. So I am going to open it up all the way and try that. I am sure I was getting to much crank case pressure. Like everything made now days, no quality control.
Thanks Scott
