E body clutch/brake pedal install #1333395
11/10/12 08:15 PM
11/10/12 08:15 PM
Outside
thedriver Offline OP
Outside
I'm starting a 4 speed conversion on my challenger soon.
I have the clutch/ brake pedal assy with clutch bracket, the long (7") threaded rod, 2 o rings, 2 white plastic bushings, and black plastic "t".
Got the whole setup from brewers, great guys, so I'm assuming I have all necessary parts to install the assembly.
Of course, I want to do this once.
Where do all the parts go?? Mainly the o rings/ threaded rod, and plastic bushings?
Any of you 4 speed e body guys got a pic of a couple angles from under the dash to help me along?
1973 challenger
Dana. 4 speed. Low deck.
Re: E body clutch/brake pedal install [Re: thedriver] #1333396
11/10/12 08:23 PM
11/10/12 08:23 PM
california
Mr D21 Offline
Mr D21  Offline
california
no instructions included?
Re: E body clutch/brake pedal install [Re: Mr D21] #1333397
11/10/12 08:25 PM
11/10/12 08:25 PM
Outside
Outside
I wish.
1973 challenger
Re: E body clutch/brake pedal install [Re: thedriver] #1333398
11/10/12 08:31 PM
11/10/12 08:31 PM
california
Mr D21 Offline
Mr D21  Offline
california
well the FSM is your next best friend !
Re: E body clutch/brake pedal install [Re: Mr D21] #1333399
11/10/12 08:50 PM
11/10/12 08:50 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Maybe this will help?
Yeah, it's hopped up to over 160...
Re: E body clutch/brake pedal install [Re: thedriver] #1333400
11/10/12 09:04 PM
11/10/12 09:04 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If your going to install a diaphragm pressure plate, don't bother installing the large overcenter spring, as you'll only need to remove it later
Re: E body clutch/brake pedal install [Re: DAYCLONA] #1333401
11/10/12 09:47 PM
11/10/12 09:47 PM
Outside
Outside
Didn't even bother to buy the over center spring. Won't need it anyways.
Thanks for the diagram?!
1973 challenger
Re: E body clutch/brake pedal install [Re: thedriver] #1333402
11/10/12 10:28 PM
11/10/12 10:28 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I just finished doing this on my 70 Cuda. It works a lot better if you take the drivers seat out, so you have more room while you are laying on your back. even with the instructions, it took me a couple of trys to get it in correctly, plus I an using the "over-center spring" now that was a pain in the but to install.
Re: E body clutch/brake pedal install [Re: 67vertman] #1333403
11/10/12 10:37 PM
11/10/12 10:37 PM
Outside
Outside
Could you post some pics up of the assembly?
1973 challenger
