I'm starting a 4 speed conversion on my challenger soon.
I have the clutch/ brake pedal assy with clutch bracket, the long (7") threaded rod, 2 o rings, 2 white plastic bushings, and black plastic "t".
Got the whole setup from brewers, great guys, so I'm assuming I have all necessary parts to install the assembly.
Of course, I want to do this once.
Where do all the parts go?? Mainly the o rings/ threaded rod, and plastic bushings?
Any of you 4 speed e body guys got a pic of a couple angles from under the dash to help me along?
