Re: Water leaks from under a-body dash
[Re: elmor]
#133304
10/07/08 12:43 AM
10/07/08 12:43 AM
Posts: 893 Tustin, CA
pishta
Tustin, CA
I believe there are drain holes in the cowl that tend to plug up with leaves and fill with water than overflow into the cab.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: elmor]
#133306
10/07/08 06:03 AM
10/07/08 06:03 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
My a-body leaked at both a-pillars. I replaced the windshield gasket and stopped the problem.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: elmor]
#133307
10/07/08 06:58 AM
10/07/08 06:58 AM
Posts: 845 Kansas
64Belvedere
super street
super street
Kansas
Do you have windshield washer system that isn't installed? I used to have a leak on my B Body, and finally figured out that the water came in thru the holes for the (then) missing mounting screws on the cowl.
[image][/image]
[Re: elmor]
#133309
10/07/08 05:14 PM
10/07/08 05:14 PM
Posts: 666 Anywhere the British Secret Se...
Moonraker
This thing leaks so bad that I popped the plugs out of the floorpans, just to drain it out. We get a lot of rain in the winter here in Oregon, so I would like to seal it up. Where can I get new windshield gaskets? I just bought a 67 Valiant that has the same problem. Front floorpans have to be replaced, because they're GONE.
All the resto places carry them(Year One, Paddock, etc) check the board vendors here first though for the best deals and customer service on restoration products.
