Small block ????? #1332870
11/09/12 06:37 PM
11/09/12 06:37 PM
Deerfield, Ohio
70dusterjohn Offline OP
Deerfield, Ohio
DO you think that I could make an honest 750 to 850 hp with one ? Turbo of course. I have an 88mm and want to put it to use. I would like to run 8.80s and 5.60s in the 1/8. What would you build. I want to keep costs down so throw mw you ideas. What do you think 340 stroker, 318 stroker, ???? No 360s I dont have one.. And remember I'm a big block guy so act as though I'm stupid.. Cause, well I am..
Re: Small block ????? [Re: 70dusterjohn] #1332871
11/09/12 07:00 PM
11/09/12 07:00 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
I don't see y not but u need a good block and some descent heads
Re: Small block ????? [Re: one bad fish] #1332872
11/09/12 07:11 PM
11/09/12 07:11 PM
dogdays Offline
dogdays  Offline
You should be able to make an easy 2.5 hp/cubic inch with big heads and turbos.. You REALLY need an aftermarket block for this level of effort, though.
R.
Re: Small block ????? [Re: dogdays] #1332873
11/09/12 09:00 PM
11/09/12 09:00 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
You will be able to make that by mistake.A 88mm should be good for 1200hp.Get a good block 360-1 heads.
Re: Small block ????? [Re: fasthawk6] #1332874
11/09/12 10:07 PM
11/09/12 10:07 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
If you are going to get a race block or ritter block, I would go 48* and run some w9s. With that set up you would have to try and keep the hp that low. LOL
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Small block ????? [Re: 1967dartgt] #1332875
11/09/12 10:50 PM
11/09/12 10:50 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
If it isn't going to be a street car you could try and fill the block. I think your goal is attainable but will definitely require a serious cylinder head and some thinking. A friend makes shy of 900 with a 4cyl DSM so why not with a SBM motor?
Re: Small block ????? [Re: SpareParts] #1332876
11/10/12 12:18 AM
11/10/12 12:18 AM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
750 to 850 with a boosted SBM???
Without question.
It's a piece of cake N/A.
Re: Small block ????? [Re: jim sciortino] #1332877
11/10/12 01:19 AM
11/10/12 01:19 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
Give us some more info bout wat u want to do with the car..... Id say an r3 block and any w series head will do the job. Heck you could do it with w2s
Re: Small block ????? [Re: 70dusterjohn] #1332878
11/10/12 10:18 AM
11/10/12 10:18 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
I have a sb w a n2o cam in it that made 749hp w a big sv1 carb.I lost a few hp w my 4150.
Re: Small block ????? [Re: fishy340] #1332879
11/10/12 10:42 AM
11/10/12 10:42 AM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
my friend mike has a duster with b1ba heads stock block twin turbo made 1100 to the tire mild tune has been 8.20 at 3200 lbs.
Re: Small block ????? [Re: 70dusterjohn] #1332880
11/10/12 11:09 AM
11/10/12 11:09 AM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i have a complete shortblock sitting in a crate fresh that will take u there ×2 w the right turbo.I mean headers and all.All u need is oil and fuel pump
Re: Small block ????? [Re: 70dusterjohn] #1332881
11/10/12 11:59 AM
11/10/12 11:59 AM
Texas Afghanistan Iraq etc.
DakFink Offline
DakFink  Offline
Keeping cost down!
340 bore and stroked with a BPE stroke kit. (4.25" stroke) about $2350 or so
Dr Js Airwolf 220 Heads for about $2300
and a good LSM or Bullet cam.
The 88mm and a good Blow Through carb.
750-850 an easy walk in the park.
Re: Small block ????? [Re: DakFink] #1332882
11/10/12 02:52 PM
11/10/12 02:52 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Keeping cost down!
What cam....
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: Small block ????? [Re: Adobedude] #1332883
11/10/12 03:44 PM
11/10/12 03:44 PM
St.Louis, Mo.
mokid Offline
mokid  Offline
St.Louis, Mo.
I run a R3 W8 motor single carb makes 850 HP I'm currently having it re-built after breaking a rod cap, and my builder a chevy race engine builder is going to make a few changes like less dish in pistons maybe cam change but insist that we can get more HP out of this motor, I will update as build goes on. best time 9.03 149 mph.
