How much can you bore a 440 #1332665
11/09/12 11:11 AM
11/09/12 11:11 AM
Ky
moparmafia Offline OP
Ky
I have a friend that took his 1977 440 block to a mopar machine shop this week to have it built for his mud truck. the shop owner told him to take it back home because it wouldn't work. he said the max you can bore any of the newer blocks is .020. He said the same thing with 400 blocks. So he talked him into buying an older 440 block he had. I have ran several 400 blocks that were .030 over with stroker cranks and have yet to have a problem. Has anyone had a failure on a block because of too much overbore on a newer block or was he just trying to get more money?
Re: How much can you bore a 440 [Re: moparmafia] #1332666
11/09/12 11:15 AM
11/09/12 11:15 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
They always use to say that, but I have had newer blocks sonic test better than an older bock, I would say that you are safer with the older block, but either way the best 60 bucks is to have it tested. Then you have no doubt in your mind as to what you can do safe.
Re: How much can you bore a 440 [Re: moparmafia] #1332667
11/09/12 11:32 AM
11/09/12 11:32 AM
an8sec70cuda Offline
I remember reading here a while back where someone sonic checked a bunch of blocks and the later model blocks were no different than the earlier ones. Any of them can be thin, best bet is to have it checked. The myth that the later model blocks are too thin is just that...a myth.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How much can you bore a 440 [Re: an8sec70cuda] #1332668
11/09/12 11:54 AM
11/09/12 11:54 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
AndyF did that article, the shop owner talked about above is an IDIOT and believes the MYTH that was put out by MP(LARRY SHEPARD) Tell your friend to take that engine build elsewhere if the guy is that stupid.
Any and ALL blocks should be sonic checked , Andy's article showed the later blocks actually had THICKER walls than the early blocks and the core shift didn't seem to be as bad. The later blocks are a little softer but that is not necessarily a bad thing. ANY block going over .030 should be sonic checked first , even the later MP SIAMESE bore blocks , Don't ask me how I know ...
Re: How much can you bore a 440 [Re: JohnRR] #1332669
11/09/12 12:15 PM
11/09/12 12:15 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i have never spent any time confirming this idea but a friend of mine that owns a machine shop told me that by looking at the cam bore bosses you can get an idea of how much core shift the block has. i don't know how reliable this method is but it's certainly worth mentioning.
look at the cam bore bosses at both ends of the block if the bored hole is noticeably offset in relation to the boss then the block has a lot of core shift. of course having the block UTd is the best idea especially if larger overbores are desired.
Re: How much can you bore a 440 [Re: jamesc] #1332670
11/09/12 12:25 PM
11/09/12 12:25 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have 2 440 blocks, one '66 & one '77, both are in cars & .030 over with about .220 minimum cylinder wall thickness left. Both had a fair amount of core shift, otherwise they'd have about .260 left IIRC.
Sonic testing is something I consider mandatory for any performance build before money is spent on pistons & machining. Also, for building HP, I prefer thicker walls over getting the next .010, .030, or whatever bigger bore.
Re: How much can you bore a 440 [Re: jamesc] #1332671
11/09/12 12:38 PM
11/09/12 12:38 PM
NEW YORK
MAXEDWEDGE Offline
MAXEDWEDGE  Offline
NEW YORK
You all can say what you want BUT i had two 400 later year blocks crack right down the middle of cylinder ,two differnt motors and different cylinders .that was with a 0.030 over bore .Spend the money and get it sonic checked , you might get lucky .
Re: How much can you bore a 440 [Re: moparmafia] #1332672
11/09/12 01:11 PM
11/09/12 01:11 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Unfortunately, you may or may not be spending money you didnt need to on another block. I have sonic checked over 400 blocks, and there is one thing that is consistent. There IS NOTHING consistent! ( the GM blocks are more consistent than the Mopars for sure) The ole MP rule of only .020 overbore is garbage. I am surprised any shop anymore doesnt sonic check a block,subcribes to that theory, and randomly has a customer assume a block is junk. Thats the shops job, to check and provide information resulting from proper procedure.Sounds like he ha d ablock he wanted to get rid of????
As far as the " good" or " bad" blocks, there is no such thing. The nickel content can be different, some blocks can be harder than others etc, but the only way to know if its good is to sonic test, magnaflux and or presssure test. I recently checked one of the vaunted " 230" blocks, standard bore. Customer paid ( i think) $300 for it bare. It didnt sonic test very good. Will need a couple sleeves to do it right. You just never know.
As far as core shift, yes, sometimes that rule stands true as to bore centerlines, cam tunnles, oil galleries etc. the problem is when you have a centered core, but how do you know if there is a thin spot or void in the casting on a cylinder. You will often find blocks that sonic well, then all of a sudden there are voids or bad spots, sometimes 1" round or bigger in a bore test. I actually cut an old block open once to confirm after deaming it junk. Sure enough, a very thin casting, along with rust, had thinned that area.
I think the shop could have done you better with a test first, but if he's your guy, then you have to roll with him. Good luck with your build..
RIP Monte Smith
Re: How much can you bore a 440 [Re: CompWedgeEngines] #1332673
11/09/12 03:35 PM
11/09/12 03:35 PM
JohnRR Offline
JohnRR  Offline
Sounds like he had a block he wanted to get rid of????
With this in mind , it did cross my mind earlier , I may have jumped to soon on calling the machine shop person an Idiot ...
Was the early block sonic checked before the build on it started ???
Re: How much can you bore a 440 [Re: JohnRR] #1332674
11/09/12 06:34 PM
11/09/12 06:34 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I took a late model block to renowned racer FJ Smith to be sonic checked. He told me I was wasting my time and money "those blocks are all too thin". I told him it was a myth and do it anyway. Guess what ... he's been converted!!
Re: How much can you bore a 440 [Re: Stanton] #1332675
11/09/12 11:41 PM
11/09/12 11:41 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I had 3 blocks sonic check this week . 70-71-78 71 was the best 70 could be used and the 78 is junk. you don't know what you got till you check them. had a friend have 5 blocks checked. only 2 of them was any good. all you can do is do all the test check and look at then hard !! all these was RB blocks.
Re: How much can you bore a 440 [Re: JohnRR] #1332676
11/10/12 12:55 AM
11/10/12 12:55 AM
Ky
Ky
The machine shop owner said it was a good block but i think it's because it was an older block and not that it was sonic checked.I told him the guy is just trying to make money off him because now he has talked my friend into a set of used cast iron indy heads to put on the block he sold him. my friend even told the owner that he is only allowed to run a stock fuel pump with a 650 single line holley but the guy said it will work.
Re: How much can you bore a 440 [Re: moparmafia] #1332677
11/10/12 09:58 AM
11/10/12 09:58 AM
JCFcuda Offline
JCFcuda  Offline
I have a 78 440 overbore 0.055 It make 700 hp aprox.
4 years in this tune. You dont want thin walls but I dont think you need the big thinkness that some say you need.
Some said the same about Al blocks they move around to much you lose to much HP. If you build one on kill you might need that thickness otherwise its not a issue.
ps I would give the shop a little break on this He might be trying to do the right thing by you and not screwing He might not be a idiot just has a different opinion.
Re: How much can you bore a 440 [Re: JCFcuda] #1332678
11/10/12 10:27 AM
11/10/12 10:27 AM
ohio
B5 GTX Offline
B5 GTX  Offline
ohio
http://www.440source.com/blockinfo.htm
Check out the link above, very interesting. I know my uncle has a newer one bored out to .060 on a stroker.
Scott
Re: How much can you bore a 440 [Re: B5 GTX] #1332679
11/10/12 05:25 PM
11/10/12 05:25 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
My '76 block is bored .055 over for a 526" stroker. I used the late model block because of the extra meat around the mains.
Re: How much can you bore a 440 [Re: Stanton] #1332680
11/10/12 07:17 PM
11/10/12 07:17 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I was going to start a new post about the blocks. I had tested but I think the Info would be good here. I got some pics and sonic test numbers. I stated that the 78 was junk not really true now that I have the numbers in my hand. so here are the numbers if you click on the pics they should get bigger so you can read them. block 1 is a 70. block 2 is a 73 and block 3 is a 78. and when I got home I found other 71 block. I will take up to check.
.Now there is some talk about looking at the meat around the cam in the front. this might hold true by a wee little bit.
this last pic is the worst one I got for that and it is a block that been bore .030 over race in my car for years, was in a super gas car before that
Re: How much can you bore a 440 [Re: VernMotor] #1332681
11/10/12 07:43 PM
11/10/12 07:43 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
I wanted to add that the 78 block does have more meat around the mains....and I am tired of move these heavy a$$ block around !!!!
Re: How much can you bore a 440 [Re: VernMotor] #1332682
11/10/12 09:00 PM
11/10/12 09:00 PM
jamesc Offline
jamesc  Offline
you know you can get them in aluminum
Re: How much can you bore a 440 [Re: jamesc] #1332683
11/10/12 09:23 PM
11/10/12 09:23 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
aluminum block wow that be nice....might be little over kill for a 550hp motor lol.. So the old age question.. how thin can you be on the thrush and non-thrush side of the cy's ?
Re: How much can you bore a 440 [Re: VernMotor] #1332684
11/10/12 10:30 PM
11/10/12 10:30 PM
jamesc Offline
jamesc  Offline
well there are a number of variables first being how hard you're going to run it. off the top of my head i'd prefer >.150 on the thrust but don't know how hard that is to find. for a given thickness a low deck is going to be stiffer because the cylinder is shorter. i'm sure running an engine into detonation doesn't help matters any as well. side loading do to stroke/piston/rod combination there are a number of factors.
there are plenty of people with more experience that have measured and built more engines so with regards to wall thickness i can't speak from a wealth of experience as to what will live and what won't. the only one i personally dealt with that split was a lo deck 500" unfilled stroker that was being run pretty hard with alcohol injection and i have to wonder if it would have split had it been filled. the owner ended up going with a megablock.
there is also the idea of filling the block either a short or tall fill. i filled both the stock blocks i raced one short and one tall. i know people have mixed feelings about filling the block but i think if it's done correctly it can't do anything but help.
i have a UT mic but haven't shot a lot of blocks. i have a couple blocks sitting around so if i get the motivation maybe i'll shoot them for the heck of it plus i need to become better acquainted with the mic i haven't used it that often.
here's a write up that Andy did with a lot of info
http://arengineering.com/tech/sonic-checking-the-mopar-big-block/
