Frnt end assembly? Backing plate-Spindel #1332334
11/08/12 02:43 PM
11/08/12 02:43 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Reassembling my 70 RR Front end. Wondering if there is a gasket etc between the brake backing plate and the spindel? Cant find anything in the service manual but want to make sure...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Frnt end assembly? Backing plate-Spindel [Re: JMCFAN] #1332335
11/08/12 04:15 PM
11/08/12 04:15 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
There may be a round foam gasket in there , check with 71TA
Re: Frnt end assembly? Backing plate-Spindel [Re: JMCFAN] #1332336
11/08/12 11:30 PM
11/08/12 11:30 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
I believe it is a foam donut gasket. I got mine fom Wilson Products in Missouri. I don't have their info though.
Re: Frnt end assembly? Backing plate-Spindel [Re: JMCFAN] #1332337
11/09/12 03:08 AM
11/09/12 03:08 AM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
No gasket on drum brakes between backing plate and spindle BUT there is a foam gasket thats in the opening where the spindle passes thru the backing plate. Only problem is they put the foam piece in and THEN welded the 2 pieces together.
I'm actually working with a guy right now to do something there. I'm making him a few test pieces. Think he was going to try to glue then in place.
The foam donut is on disk brakes. Goes between the spindle and the metal splash plate.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
