date code on engine #1332164
11/08/12 12:20 AM
11/08/12 12:20 AM
Indiana
P
plum crazy mike Offline OP
P
Indiana
Looking at a 340 cuda and door sticker has it as a 2-70 build on car. When I look at engine block what should the date as far as month and year be on the block? Thanks in advance.
Re: date code on engine [Re: plum crazy mike] #1332165
11/08/12 12:27 AM
11/08/12 12:27 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
What are the numbers on the front of the block below the driver's side heard surface?
One of my cars had 417 on the fender tag, 4-70 on the door sticker but the original engine was assembled 4-22-70.
Re: date code on engine [Re: Alaskan_TA] #1332166
11/08/12 12:40 AM
11/08/12 12:40 AM
Indiana
P
P
Indiana
Thanks for the info. My buddy that was with me is a ford guy and he said mustangs engines were 2-3 months before car.
Re: date code on engine [Re: plum crazy mike] #1332167
11/08/12 12:44 AM
11/08/12 12:44 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
First thing you do? Forget anything a Ford or GM owner tells you! While there may be SOME similarities, Mopars were generally pretty unique.
Like Barry eluded to, there's no set rules when it comes to scheduled production dates and engine assembly dates, just generalizations.
Two things you can count on for 99.99 certain. The engine assembly date is the ACTUAL date it was assembled, and the month reflected on the door sticker is the ACTUAL month the car was completed. However, the cars Scheduled Production Date may have varied (usually by a few days, but possibly even weeks or months!). Also, various engines seemed to be cast and assembled at varying times before being used in production, some were years appart while others were mere weeks.. Generally speaking 340's were cast and assembled fairly quickly, usually a month or two after being cast, and USUALLY made it into cars within a few days to a week or so depending on the shipping times to the various assembly plants.
Re: date code on engine [Re: plum crazy mike] #1332168
11/08/12 12:48 AM
11/08/12 12:48 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Mopar casting dates can be dated years before used in a car. The assembly date of the engine itself may vary quite a bit, either before or after the date they hoped to build the car (SPD).
Re-stamped blocks, fake fender tags, broadcast sheets & door stickers are out there, so if you are not sure what to look for, find someone to help you out that knows how.
