I have been having some trouble with my wipers not working all the time and the last time out they wouldn't go at all so before I go throwing $$ at it I would like some input.
First the dash switch 6 wires pink is 12+ and brown goes out the the washer motor which works fine.
The other four are green, red, brown, blue and as far as I can tell the green goes through the position switch to the armature so that should make the other three the speeds and the unit goes back to ground through the external strap.
If that is correct then I should get different ohms readings from each pin to the unit body.
Would anyone know what those readings should be.
