purple stick? #1330400
11/04/12 02:16 AM
11/04/12 02:16 AM
Spring Valley ,Ca.
moparsquid Offline OP
Spring Valley ,Ca.
I had to pull my intake off to replace a bent valve in the head so I figured id check the cam if it had any marks on it. I was told that it was a Crower solid cam ,when i inspected it the front 1/3 was painted purple . did crower paint there cams this color I know MP did?
Re: purple stick? [Re: moparsquid] #1330401
11/04/12 08:53 AM
11/04/12 08:53 AM
Baltimore, MD
MadMax58 Offline
MadMax58  Offline
Baltimore, MD
Crower cams are black. Mopar Performance cams are purple.
Re: purple stick? [Re: MadMax58] #1330402
11/04/12 02:37 PM
11/04/12 02:37 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks I thought so also how can i id a cam in the car from the valley ?
Re: purple stick? [Re: moparsquid] #1330403
11/04/12 02:53 PM
11/04/12 02:53 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I think just measuring the valve lift rotating the assembly.
Re: purple stick? [Re: NachoRT74] #1330404
11/04/12 03:23 PM
11/04/12 03:23 PM
Spring Valley ,Ca.
Spring Valley ,Ca.
thanks ,but is there any id numbers on the cam itself ?
Re: purple stick? [Re: moparsquid] #1330405
11/04/12 04:32 PM
11/04/12 04:32 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
nope, nada, zilch, no...
I am truckless..
