340 4-spd - solid setup ? #1329977
11/02/12 10:13 PM
11/02/12 10:13 PM
beentheredonethat
AverageJoe Offline OP
beentheredonethat
I'm starting resto on an original 70 Swinger, 340 4spd car. I'd like to run hard on occasion and was wondering if my solid lifter setup from a 273 I had lying around would be beneficial to performance. I'm no mechanic so : what would the advantage/disadvantages be ?
Re: 340 4-spd - solid setup ? [Re: AverageJoe] #1329978
11/02/12 10:26 PM
11/02/12 10:26 PM
If your talking about swapping the cam and lifters, pushrods and rocker asembly yje 340 cam is alot better for the 340, don't swap the 273 cam into the 340 If your talking about using the rocker arms and shafts and buying a set of proper fitting pushrods for your current cam it may help a tiny bit if the motor runs okay now If your installing a bigger cam than stock then the adjustable rocker assembly from the 273 is definetly worth having
Re: 340 4-spd - solid setup ? [Re: Cab_Burge] #1329979
11/04/12 10:14 AM
11/04/12 10:14 AM
beentheredonethat
beentheredonethat
Yes - guess I should have added that I would be picking a cam and correct pushrods for the combo. I had also read somewhere that I could have the 273 rockers "upgraded" by a company in CA (sorry, don't recall the details as it's been a few years).
Re: 340 4-spd - solid setup ? [Re: AverageJoe] #1329980
11/04/12 01:09 PM
11/04/12 01:09 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Rocker Arm Specalities
Re: 340 4-spd - solid setup ? [Re: astjp2] #1329981
11/04/12 04:49 PM
11/04/12 04:49 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Up graded to what ????? They have the same 1.5 ratio that the 318, 340 and 360 uses...
I am truckless..
Re: 340 4-spd - solid setup ? [Re: 340SHORTY] #1329982
11/04/12 06:09 PM
11/04/12 06:09 PM
beentheredonethat
beentheredonethat
This is the "upgrade" I was referring too, wouldn't have asked had I found this earlier :
https://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=5906565&Main=5906170
What's up with the "?????" ? , total confusion ?
Re: 340 4-spd - solid setup ? [Re: AverageJoe] #1329983
11/13/12 10:39 PM
11/13/12 10:39 PM
beentheredonethat
beentheredonethat
Kinda wanted some feedback regarding advantages of the setup as I'm no mechanic and have not driven a solid lifter car so ............ just know I don't plan on avoiding the redline (show AND go).
