dana 60 ujoint #1329915
11/02/12 03:47 PM
11/02/12 03:47 PM
pennsylvania USA
W
wantabee Offline OP
wantabee  Offline OP
W
pennsylvania USA
I changed the rear in my 69 Coronet from a Moser 60 rear to a stock 69 Dana 60,the drive shaft has 1.188 diam. caps with outside rings,the rear yoke has 1.125 caps with inside rings, both are3.662 wide dose any body make a ujoint to fit this?
Thanks Allen
Re: dana 60 ujoint [Re: wantabee] #1329916
11/02/12 04:01 PM
11/02/12 04:01 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
This might be a good place to check with.
http://www.dennysdriveshaft.com/c90_u_joints.html
Re: dana 60 ujoint [Re: SNK-EYZ] #1329917
11/02/12 10:33 PM
11/02/12 10:33 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Precision u joint does the small joint number is 315G the loathe ozone is 316 & there's a conversion joint too
Re: dana 60 ujoint [Re: BulletBob] #1329918
11/09/12 06:26 PM
11/09/12 06:26 PM
pennsylvania USA
W
wantabee Offline OP
wantabee  Offline OP
W
pennsylvania USA
I found the right u joint it is a CarQuest 2-1153. Thanks for the help
