Demon Dual Snorkle Hood Scoop? #1329595
11/01/12 06:23 PM
11/01/12 06:23 PM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hi Guys, my uncle is putting a Demon dual snorkle fiberglass hood scoop on his 73 Duster. He was told the holes under the scoop are supposed to be 4 in diameter. He has purchased two gaskets for them. He wants to make sure this is correct. Does anyone know the size and position of the two holes under the hood scoop. He wants it to look like it was a factory option for the 73 Duster.
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: Demon Dual Snorkle Hood Scoop? [Re: ScottG] #1329596
11/01/12 10:53 PM
11/01/12 10:53 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
I can't say for sure if the holes are 4 inches or not, but they had gaskets just for that. It has been almost 40 years since I did the same thing to my Demon. I bought the gaskets that were made for the holes. I believe the holes were cut so they missed the cross bracing under the hood. Not sure but I think they can only go in between the bracing, so, I don't think there was an exact measurement taken, just so it fit in the space. Now that doesn't mean mine were in the right place, but they were over top of the carb. Hope that helps.
Re: Demon Dual Snorkle Hood Scoop? [Re: Dodgeguy101] #1329597
11/01/12 10:57 PM
11/01/12 10:57 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
The holes 4 1/8" and it's easy to see where the holes go based on the cutout section on the cross-member
Still looking for LM29H1B415501, '71 Demon 340
Re: Demon Dual Snorkle Hood Scoop? [Re: PAULS_340] #1329598
11/02/12 08:24 PM
11/02/12 08:24 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
pic might help
Re: Demon Dual Snorkle Hood Scoop? [Re: PAULS_340] #1329599
11/02/12 09:01 PM
11/02/12 09:01 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
That pic is of a 71 with the two scoops. He needs a pic of a 72 or 73 with that style scoop. My car is missing the gaskets, but I found this pic on the web.
Re: Demon Dual Snorkle Hood Scoop? [Re: pinkduster] #1329600
11/03/12 08:53 AM
11/03/12 08:53 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Thanks Guys, this info helps alot.
Thanks Again
Scott
