correct oil and additive for break inn?????????
#132903
10/06/08 12:29 PM
10/06/08 12:29 PM
Posts: 208 netherlands
smallstroker
netherlands
i have the kendall gt 1 20w50 oil is that good oil for the break inn period? also i have a break inn oil additve from lucas: http://store.summitracing.com/partdetail...mp;autoview=skubut here in the netherlands i heard that the lucas additive is not good . it can cause little air bubbles in the oil i want to know for sure what i must use , i don;t want to destroy my engine on the first start.. thanks
Re: correct oil and additive for break inn?????????
[Re: smallstroker]
#132904
10/06/08 12:40 PM
10/06/08 12:40 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
I use Rottela 15 40 and a bottle of Comp Cams break in additive in mine
[Re: smallstroker]
#132905
10/06/08 12:50 PM
10/06/08 12:50 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
I would go ahead and use the Lucas and the Kendall. I believe the Lucas helps.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: doctor_mopar]
#132906
10/06/08 01:00 PM
10/06/08 01:00 PM
I broke mine in with Valvoline VR1 and a bottle and a half of ZDDP Plus. So far it looks like my colid cam has lived. I also used GM's EOS for bearing and other assorted assembly lubrication.
[Re: smallstroker]
#132908
10/06/08 11:27 PM
10/06/08 11:27 PM
Posts: 343 Ft Worth,Tx
71mopar383
super street
super street
Ft Worth,Tx
71 Charger
[Re: 71mopar383]
#132909
10/07/08 07:30 AM
10/07/08 07:30 AM
doctor_mopar
Slidell, La.
Never seen a problem with Lucas in Real Life ! Never seen foamed up lubricant with it. Don't know how Bob manages it, but remember,He is just showing you his web site test. Who knows what is going on for real in his test ?
[Re: doctor_mopar]
#132910
10/07/08 08:05 AM
10/07/08 08:05 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Depends on how old the GT 1 is.If it is green it is the good stuff,if not it is just plain oil sold under the Kendall name.The Kendall name has been sold twice and is now owned by Conoco-Philips in Houston,TX.The Kendall refinery in Bradford,PA is now owned by Brad Penn and is still producing the original GT 1 under their name.Here is the link,read the history.You will also find the Grade I racing oil has as much or more zinc than anything else on the market.
http://www.bradpennracing.com/
[Re: 62maxwgn]
#132911
10/07/08 10:04 AM
10/07/08 10:04 AM
Posts: 1,143 Imlay City, MI
DTT
super gas
super gas
Imlay City, MI
I use Rotella and a bottle of GM's EOS...Its available from the dealer.
1978 Pro Street D100
1936 Dodge truck (Hot rod)
1957 Plymouth Plaza
1962 Chrysler 300
1964 Dodge 440
1995 Jeep Grand Cherokee
1971 Big Block Demon (Dads)
[Re: smallstroker]
#132913
10/08/08 03:41 PM
10/08/08 03:41 PM
doctor_mopar
Slidell, La.
Too many opinions, and some of the guys are a little paranoid. I still say use your Kendall with the Lucas. You are using a high quality oil with a break in additive ! Go for it !
[Re: smallstroker]
#132914
10/08/08 04:18 PM
10/08/08 04:18 PM
62maxwgn
Blair County,PA
so the kendall gt1 racing green is also not good???
than is switch to bradd penn but that twice as expensive here in the netherlands
As long as it is green,it is good..
[Re: challengermike]
#132918
10/12/08 08:52 AM
10/12/08 08:52 AM
RapidRobert
I am going to try that(extra qt or 2). I think that's an excellent idea. I also think it's critical for there to be enough lifter/bore clearance for the lifters to spin. I check during mockup by cleaning bore/lifters, then lube with WD40 raise lifter off a lobe with my finger & let go & should fall onto the lobe with a definite thunk rather than slowly sliding down. Also I was impressed with this. Read the "breakin secrets" at www.mototuneusa.com
