67 red interior parts #1328212
10/29/12 05:53 PM
10/29/12 05:53 PM
NO RUST IN AZ!!!
azmopar Offline OP
azmopar  Offline OP
NO RUST IN AZ!!!
been doing some checking on parts is 67 RED(metallic red) special, or is it a one year ionly color?
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: 67 red interior parts [Re: azmopar] #1328213
10/29/12 08:33 PM
10/29/12 08:33 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I do believe it is. I had a 67 Dart 2-door sedan with the same color as yours, and I had a 68 GTS with red interior that looked like a different shade, but I did not have them both at the same time so I am not 100% sure.
JB Rhinehart, Realist
A-Body's RULE!
Re: 67 red interior parts [Re: Rhinodart] #1328214
10/30/12 06:29 AM
10/30/12 06:29 AM
NO RUST IN AZ!!!
azmopar Offline OP
azmopar  Offline OP
NO RUST IN AZ!!!
problem im having is the 68 pieces im finding are either maroon(dark red) or red like fire engine red
#NONIKESEVER
Re: 67 red interior parts [Re: azmopar] #1328215
10/30/12 11:19 AM
10/30/12 11:19 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
That is what I mean, the shades are definitely different.
A-Body's RULE!
Re: 67 red interior parts [Re: azmopar] #1328216
10/31/12 12:27 PM
10/31/12 12:27 PM
Detroit
L7VERT Offline
L7VERT  Offline
Detroit
My '67 R/T is a red-interior car and I'm going through this right now.
The interiors actually used three different paints; the suede finish on the i.p., column, etc. The low-gloss on plastic panels and console, and the gloss on the inner door frames.
According to the '67 Dodge shop manual, the Ditzler code for the gloss paint is 71545, even though it was given a different name for different models. The Chrysler code, however, is different for Medium Red (Coronet/Charger) than it is for Dart (Cardinal Red). I wonder if there was a misprint in the manual because I purchased some paint to the Ditzler code and it is isn't even close to the original color. It is a burgundy where my car is more of a coppery/orangish red. I ended up color-matching to an oversprayed section of the door that was covered by the panel.
Just as an FYI, the color of upholstery from the aftermarket (in my case, Legendary) is very good. Also, the touch-up spray that you can buy in the rattle can (code 520, I believe) is very close to original but it sprays out very flat and if you try to clear it the color is changed. It would be nice if the people that supply that paint could make it in a gloss version.
Re: 67 red interior parts [Re: L7VERT] #1328217
10/31/12 12:47 PM
10/31/12 12:47 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I totally agree with the coppery/orangesh red statement, it is very hard to express the exact color used in 67. It is almost a candy/mettalic look.
A-Body's RULE!
Re: 67 red interior parts [Re: Rhinodart] #1328218
10/31/12 05:35 PM
10/31/12 05:35 PM
NO RUST IN AZ!!!
azmopar Offline OP
azmopar  Offline OP
NO RUST IN AZ!!!
my interior parts from PUI? are considered mettalic red 710 is the code and yes they match perfectly
#NONIKESEVER
