Need some help installing a torque converter #1327269
10/28/12 10:03 AM
10/28/12 10:03 AM
Tampa
DusterDave Offline OP
Tampa
I'm not able to get that last "clunk" to fully seat the converter hub to the pump lugs. I've read that the lugs should be in the 6 and 12 o'clock position. If this is true, how can I move the lugs? Mine are at roughly the 3 and 9 o'clock position. Any tips on how to get it to seat all the way?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Need some help installing a torque converter [Re: DusterDave] #1327270
10/28/12 10:11 AM
10/28/12 10:11 AM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Is the trans still all the way out of the car? If so, stand it on the tailshaft (gently) and spin the convertor until it drops in. Should take no more than 10 seconds.
Old, tired, and sometimes broke down. Me, not my car...
Re: Need some help installing a torque converter [Re: Shoozy] #1327271
10/28/12 10:30 AM
10/28/12 10:30 AM
Tampa
Tampa
Tried that. If I look at it from a side angle, the raised pads on the converter where the flexplate mounts to, stick out past the mounting face of the bellhousing. They should be inside, right?
Re: Need some help installing a torque converter [Re: DusterDave] #1327272
10/28/12 10:40 AM
10/28/12 10:40 AM
Southern by Choice
Shoozy Offline
Shoozy  Offline
Southern by Choice
Yep. There was a recent post on this very thing in the race section you can refer to but your pads should be "inside" the mounting surface a bit (opinions vary but I was good with 1/8 - 3/16). I had a very stubborn one on a race 727 years ago that would fight hard. The on-end was the only way I could get it in and then half the time it popped out on me while installing the trans. I feel your pain!
Re: Need some help installing a torque converter [Re: Shoozy] #1327273
10/28/12 11:01 AM
10/28/12 11:01 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Look down the neck of the converter to make sure it is welded on properly. I had one that I just could not get to go in, and the neck was welded slightly off center.
Re: Need some help installing a torque converter [Re: DusterDave] #1327274
10/28/12 11:15 AM
10/28/12 11:15 AM
Forest Lake, Minnesota
superbeejim Offline
superbeejim  Offline
Just take a small pocket screwdriver and turn the inner pump gear untill the lugs are at 12 and 6 oclock
Re: Need some help installing a torque converter [Re: DusterDave] #1327275
10/28/12 11:25 AM
10/28/12 11:25 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Just line up the slots to where the pump tabs are at, 9 and 3 oclock in your case, and do some careful wiggling of converter turning it just a hair back and forth rotationwise and it should go in. The mounting lugs should sit about 1/2 inch or more behind mounting surface of trans-engine.
Re: Need some help installing a torque converter [Re: buildanother] #1327276
10/28/12 11:52 AM
10/28/12 11:52 AM
Tampa
Tampa
SUCCESS!! I took a long thin flat screwdriver and slid the pump lugs to the 6 and 12 position, and after a few turns, she fell into place. Funny thing is, it was overcast all morning, but as soon as I made the last effort to fit the converter, the sun came out.
Re: Need some help installing a torque converter [Re: Shoozy] #1327277
10/28/12 10:34 PM
10/28/12 10:34 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It took hanging mine to get it to drop in.
After that it dropped right in.
