Gear change/ 60' loss #1326969
10/27/12 03:11 PM
10/27/12 03:11 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I need a gear change in my Duster and just 3 days ago had a new best of 1.49 60' and a 10.95 ET. Problem is that it hits the rev limit (7k) in 3rd around 1000'
I wonder how much 60' I will give up going from 4.86 to 4.56 gears? This is a 3.58 stroke 374 inch engine. Any guesses or personal experiences?
Yeah, it's got a smallblock.
Re: Gear change/ 60' loss [Re: 340B5] #1326970
10/27/12 03:14 PM
10/27/12 03:14 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
We lost none, at all... I really dont think that the 56 is going to be a big enough drop to make a difference, I think I gained maybe 200 or so rpm. So I still feel that you would hit the rev before the line. I ended up going to a 4.30 and the car picked up a little more on top end, and again lost nothing in the 60ft. Thats with a 30" tall tire..
Re: Gear change/ 60' loss [Re: 340B5] #1326971
10/27/12 03:21 PM
10/27/12 03:21 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
What size tire? Try a 2 inch taller tire and that would be close to the 4.56s.
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Gear change/ 60' loss [Re: 340B5] #1326972
10/27/12 03:24 PM
10/27/12 03:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
is the combo done at 7K?
Re: Gear change/ 60' loss [Re: 70dusterjohn] #1326973
10/27/12 03:35 PM
10/27/12 03:35 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I would be happy if I didn't loose any, and yes I thought about still hitting the limiter, but it should be for less time anyway.
Slippery: I already have the gears, so that fits the budget better.
J body: The combo should be done before that. I have factory iron J heads(worked over some)I'm gonna guess 6700 or so, but I haven't felt it nose over before the limiter. I've only made 5 complete passes w/ the combo and I'm still getting re-acquainted with the car after a 2 yr hiatus.
Re: Gear change/ 60' loss [Re: 340B5] #1326974
10/27/12 04:43 PM
10/27/12 04:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
That gear change should drop you 500 rpm may cost you .01 in the 60 foot.
I would just race the limiter to 7600 RPM is your friend! :-)
Re: Gear change/ 60' loss [Re: Dodgem] #1326975
10/27/12 04:54 PM
10/27/12 04:54 PM
Renton Washington
Triple Threat Offline
Renton Washington
If the converter is big enough, it shouldn't hurt too much, maybe .02 to 60 foot, but the car will run better down track...
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Gear change/ 60' loss [Re: Dodgem] #1326976
10/27/12 04:59 PM
10/27/12 04:59 PM
Washington
skrews Offline
skrews  Offline
Washington
Few years back I tried 4.30, 4.56, 5.13. No notable difference, except that the 5.13 would turn the tire a little off the line sometimes making the car inconsistent. This was running in a 7.5 ET 1/8 mile car for what its worth. I've watched alot of guys try really deep gear hoping to shave of some ET and lower the 60 footers, only to find no gains at all.
Re: Gear change/ 60' loss [Re: Triple Threat] #1326977
10/27/12 05:01 PM
10/27/12 05:01 PM
Deerfield, Ohio
Deerfield, Ohio
Like I said we did it with zero change. Didn't make a difference at all. If you have them and can do it, heck try it. What are you out? Then if need be you could go up 2 in the tire size(if you can) or go to a 30 for next year. Are you running an 8 3/4 ? Where you located. I have complete pigs in 489, 456, and 430.. Heck I got a 410 also....
Re: Gear change/ 60' loss [Re: 70dusterjohn] #1326978
10/27/12 05:16 PM
10/27/12 05:16 PM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
Thanks for the replies. It looks like I'll be good to go w/ the 4.56's. The trans has the 2.74 low anyway.
Re: Gear change/ 60' loss [Re: 340B5] #1326979
10/27/12 08:22 PM
10/27/12 08:22 PM
gregsdart Offline
gregsdart  Offline
going from 4.86 to 4.56 is only a 6.2 percent drop in gear ratio, so it should see 400 rpm drop. I am betting it will run as good or better. With the 2.74 low you still have a 12.49 starting line ratio, and that is pretty high.
Re: Gear change/ 60' loss [Re: gregsdart] #1326980
10/27/12 08:40 PM
10/27/12 08:40 PM
tboomer Offline
tboomer  Offline
Greg...I find that interesting. If I crossed the line at 6400 instead of 6800,I would still be in my powerband. Might run a hair faster with 4.56 instead of 4.88s..
Re: Gear change/ 60' loss [Re: tboomer] #1326981
10/27/12 09:23 PM
10/27/12 09:23 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
One school of thought is that you should peak at the 1,000 foot mark which by then most of the acceleration has reduced your ET and you are already at a higher MPH for the last 320 feet...
This assumes the engine can handle the rpm and is not nosing over...
My motor made peak HP at 7,200 rpm and I cross the stripe at 8,000 - 8,100 rpm. I think it ET's decent...
Best way to find out is to test it, so let us know how the 4.56's affected the ET and MPH once you cahnge.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
Re: Gear change/ 60' loss [Re: cudabin] #1326982
10/28/12 01:27 AM
10/28/12 01:27 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, changing gears does affect E.T. and 60' times. went from 5.13 & 29.5 tire to 5.57 & 30" tire, E.T. dropped .30 & gained 1 MPH. 60', dropped .13. car was faster period!!! also, rpm was 6400 after is 7000 rpm +. it doesn't lay down last 300 ft either.
Re: Gear change/ 60' loss [Re: perfmachst] #1326983
10/28/12 11:24 AM
10/28/12 11:24 AM
off the grid
340B5 Offline OP
340B5  Offline OP
off the grid
I've tried to factor in everything. The tires will turn 7.6 times in 60', stall is increased ever so slightly w/ the 4.56's, etc. I think I'll check the logbook today and see what going from 4.56 to 4.86 did for the 345 in engine a few years back.
