Gear change/ 60' loss
#1326969
10/27/12 03:11 PM
10/27/12 03:11 PM
Posts: 1,532 off the grid
340B5
off the grid
I need a gear change in my Duster and just 3 days ago had a new best of 1.49 60' and a 10.95 ET. Problem is that it hits the rev limit (7k) in 3rd around 1000'
I wonder how much 60' I will give up going from 4.86 to 4.56 gears? This is a 3.58 stroke 374 inch engine. Any guesses or personal experiences?
Yeah, it's got a smallblock.
Re: Gear change/ 60' loss
[Re: 340B5]
#1326971
10/27/12 03:21 PM
10/27/12 03:21 PM
Posts: 1,142 Central New York
slippery440
Crybaby440
Crybaby440
Central New York
What size tire? Try a 2 inch taller tire and that would be close to the 4.56s.
If the MODS did their job I would not be hitting the notify MOD button. LOL
[Re: 340B5]
#1326972
10/27/12 03:24 PM
10/27/12 03:24 PM
Posts: 13,189 aZLiViN
J_BODY
aZLiViN
[Re: 70dusterjohn]
#1326973
10/27/12 03:35 PM
10/27/12 03:35 PM
340B5
off the grid
We lost none, at all... I really dont think that the 56 is going to be a big enough drop to make a difference, I think I gained maybe 200 or so rpm. So I still feel that you would hit the rev before the line. I ended up going to a 4.30 and the car picked up a little more on top end, and again lost nothing in the 60ft. Thats with a 30" tall tire..
I would be happy if I didn't loose any, and yes I thought about still hitting the limiter, but it should be for less time anyway.
Slippery: I already have the gears, so that fits the budget better.
J body: The combo should be done before that. I have factory iron J heads(worked over some)I'm gonna guess 6700 or so, but I haven't felt it nose over before the limiter. I've only made 5 complete passes w/ the combo and I'm still getting re-acquainted with the car after a 2 yr hiatus.
[Re: Dodgem]
#1326975
10/27/12 04:54 PM
10/27/12 04:54 PM
Triple Threat
Renton Washington
If the converter is big enough, it shouldn't hurt too much, maybe .02 to 60 foot, but the car will run better down track...
[Re: 70dusterjohn]
#1326978
10/27/12 05:16 PM
10/27/12 05:16 PM
340B5
off the grid
Thanks for the replies. It looks like I'll be good to go w/ the 4.56's. The trans has the 2.74 low anyway.
[Re: 340B5]
#1326979
10/27/12 08:22 PM
10/27/12 08:22 PM
Posts: 10,008 Frostbitefalls MN (Rocky&Bullw...
gregsdart
going from 4.86 to 4.56 is only a 6.2 percent drop in gear ratio, so it should see 400 rpm drop. I am betting it will run as good or better. With the 2.74 low you still have a 12.49 starting line ratio, and that is pretty high.
[Re: tboomer]
#1326981
10/27/12 09:23 PM
10/27/12 09:23 PM
Posts: 903 Saskatchewan, Canada
cudabin
One school of thought is that you should peak at the 1,000 foot mark which by then most of the acceleration has reduced your ET and you are already at a higher MPH for the last 320 feet...
This assumes the engine can handle the rpm and is not nosing over...
My motor made peak HP at 7,200 rpm and I cross the stripe at 8,000 - 8,100 rpm. I think it ET's decent...
Best way to find out is to test it, so let us know how the 4.56's affected the ET and MPH once you cahnge.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: perfmachst]
#1326983
10/28/12 11:24 AM
10/28/12 11:24 AM
340B5
off the grid
I've tried to factor in everything. The tires will turn 7.6 times in 60', stall is increased ever so slightly w/ the 4.56's, etc. I think I'll check the logbook today and see what going from 4.56 to 4.86 did for the 345 in engine a few years back.
