FuelLine diamter question. #1326618
10/26/12 08:17 PM
10/26/12 08:17 PM
Posting from 1893 in NW FL
TheBlueBeast Offline OP
OK I am being really lazy here. I want to check and see IF the local chain parts store has new fuel line so i can replace the rubber ones on TBB that can stand E-15 with no worries of the lines getting eaten.
That being said. I think it is 3/8 diameter but I may be wrong. It is a 440 factory car for those who are unaware.
So am I right 3/8 or is it 5/16?
Kevin
edited because I am stupid. See post below.
Re: FuelLine diamter question. [Re: TheBlueBeast] #1326619
10/26/12 10:22 PM
10/26/12 10:22 PM
OK I am being really lazy here. I want to check and see IF the local chain parts store has new fuel line so i can replace the rubber ones on TBB that can stand E-85 with no worries of the lines getting eaten.
Thanks Kevin
Measure the inside diameter and then decide what out what you want to do I would probally replace it with 1/2 inch line and the pick up also, especially using E85
Re: FuelLine diamter question. [Re: Cab_Burge] #1326620
10/26/12 10:26 PM
10/26/12 10:26 PM
I misspoke. I mean to be able to use regular unleaded that has ethanol in it. I have seen a few guys get bit during storage. I will correct the post.
Sorry.
I meant E-15. I forgot that it is percentage of ethanol not percentage of gasoline.
Re: FuelLine diamter question. [Re: TheBlueBeast] #1326621
10/27/12 04:30 PM
10/27/12 04:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If you use rubber use fuel injection hose.Its more but will stand up.Standard 440 should be 5/16s.I believe only Hemis and 6 packs got 3/8s.Rocky
Chrysler Firepower
Re: FuelLine diamter question. [Re: therocks] #1326622
10/27/12 06:56 PM
10/27/12 06:56 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
