If wasn't enough, one more about TQs
#1325963
10/25/12 02:51 PM
10/25/12 02:51 PM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
if you are trying to get a richer mix when rear throttles are opening, what you would do:
-bigger rear jets -add tension to the top air vent -limit the top air vent opening -more level on floaters
-a combo of the options mentioned... name it -none of the above... make mention.
need to note I already have the bigger jets factory got available ( .98 and .143 ) on stock unmodified carbs.
Using 2005 rods which it looks the ones what lets more fuel coming in, 1/4 of turn more on top air vent spring and limited a little bit the opening of the vent door.
I'm in doubts of the metering rod link adjustment. Some kits says get it full bottmed and then adjust from there, some other specify a height from top of front vent tower ( I can't recall the distance ) which is waaaay higher than the adjustment from bottom what other instructions sheets says
Re: If wasn't enough, one more about TQs
[Re: NachoRT74]
#1325964
10/25/12 03:03 PM
10/25/12 03:03 PM
Posts: 2,093 oberlin, Ohio
Rapid340
oberlin, Ohio
easiest methods:
1) bigger jets
2) limit air door opening.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
[Re: DaytonaTurbo]
#1325966
10/25/12 03:06 PM
10/25/12 03:06 PM
NachoRT74
Valencia, España
edited a little the post before you posted.
must say also the floats are already at 29/32"
[Re: DaytonaTurbo]
#1325967
10/25/12 03:12 PM
10/25/12 03:12 PM
NachoRT74
Valencia, España
I'm trying to hunt a carb strip kit ( 10-203 ) before modify rear jets I have extras around... which already looks I found it.
now... if getting bigger rear jets, can I readjust the floaters to set them a little bit lower ? specially being the problem IT LOOKS to be just on rears, so why to keep the 29/32" float adjustments if not needed on regular cruising ? ( so front throttles )
I'm working on save from pinging... I have got success on all small adjustments done. At this moment just getting pinging beating hills on highways with A/C on.
but mileage is getting really bad. I know is logical if you get a richer mixture will get a bad mileage, but the change on mileage has been radical on last adjustments.
Power increase has been also an improve.
trying also to get from 7 ( NGK ) plugs heat range I'm running at this moment when I was searching for the pinging cause, to the more standard 5 heat range
[Re: NachoRT74]
#1325968
10/26/12 01:27 AM
10/26/12 01:27 AM
DaytonaTurbo
Manitoba, Canada
See my post in this thread for info on float height and setting the primary metering rod tree. https://board.moparts.org/ubbthreads/show...rue#Post7292199Adjusting the primary metering rod tree will not affect air/fuel ratio at full throttle, only at part throttle. Tune your primaries by checking spark plug color if you don't have a wideband oxygen sensor. If you are still getting ping, you might need to back your timing down a little. Are you running vacuum advance on your distributor? If so, try adjusting the vacuum advance can with an allen key, you might just have too much vacuum advance coming in too early.
[Re: DaytonaTurbo]
#1325969
10/26/12 03:34 PM
10/26/12 03:34 PM
NachoRT74
Valencia, España
I already run the dist with vacuum unplugged, no change.
I'm already at 12º-14º. less than that will be too loopey than wished.
engine combo for those who don't know:
400 stroked to 3.75 KB215 pistons 282HDP crower cam 10.3 static CR average ( say average because block was uncorrectly decked, with slope from front to rear )
[Re: NachoRT74]
#1325970
10/29/12 02:02 PM
10/29/12 02:02 PM
NachoRT74
Valencia, España
what could change the float level setup on a TQ ?
[Re: NachoRT74]
#1325972
10/29/12 08:48 PM
10/29/12 08:48 PM
NachoRT74
Valencia, España
One more:
I set the floats at 29/32" being BRASS... I have read this adjustment is more proper to nitro floaters ?
