67 GTX that is bound and determin to be a vibrator #1325820
10/25/12 10:33 AM
10/25/12 10:33 AM
south central nebraska
GI Moparman Offline OP
A friend of mine has a 67 gtx that was restored bout 10 years ago and is very anal about how it is taken care of. He put it away last fall and when it came out of hibernation this spring it had a vibration that wasnt noticed before. Had tires checked and rebalanced, tried a different set of tires, 3 different drive shafts and even had the last one sent in and rebalanced. We put new motor mounts and trans mount in and the vibration is still there. The vibration starts in at about 75 to 80 and stops when you get over 100. If you run it up to about 110 and let out of it, when it gets down to about 90 it really gets bad down to about 75 then stops vibrating. I know what the speed limits are and tried to explain that to him but he says it shouldnt vibrate at any speed and he is right. Any ideas?
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325821
10/25/12 10:52 AM
10/25/12 10:52 AM
Canfield,Ohio,USA
gassy66 Offline
gassy66  Offline
Canfield,Ohio,USA
Can You feel any vibration in the Engine,running It in neutral??
Re: 67 GTX that is bound and determin to be a vibrator [Re: gassy66] #1325822
10/25/12 11:18 AM
10/25/12 11:18 AM
No vibration in neutral. We have taken rpm up close to 5ooo and engine is smooth as can be.
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325823
10/25/12 11:19 AM
10/25/12 11:19 AM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
A friend with 35+ years in the frame and alignment business says vibrations over 60 mph are usually tires or wheels. Has he swapped wheels and tires or just tires from possibly the same balancer?
Re: 67 GTX that is bound and determin to be a vibrator [Re: moparpollack] #1325824
10/25/12 12:51 PM
10/25/12 12:51 PM
we put a set of wheels and tires off of a different car on it and it had same vibration with the new wheels and tires.
Re: 67 GTX that is bound and determin to be a vibrator [Re: moparpollack] #1325825
10/25/12 02:09 PM
10/25/12 02:09 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Driveline angle...
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325826
10/25/12 02:12 PM
10/25/12 02:12 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I would check bearing play on all wheels. I had a rear axle shaft bearing start to go bad on me and it caused vibration. They do get dry sitting over the period of a few months as they are lubricated by the differential fluid.
Re: 67 GTX that is bound and determin to be a vibrator [Re: wesgtx440] #1325827
10/25/12 02:20 PM
10/25/12 02:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Not an 8.75 or a Dana..
Re: 67 GTX that is bound and determin to be a vibrator [Re: 1_WILD_RT] #1325828
10/25/12 02:26 PM
10/25/12 02:26 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Yep, the outer bearing on an 8.75 and dana 60 for each rear axle shaft is lubed by the gear oil.
Re: 67 GTX that is bound and determin to be a vibrator [Re: wesgtx440] #1325829
10/25/12 02:40 PM
10/25/12 02:40 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I don't think so. Mine has an axle seal between the bearing and the end of the tube where the gear oil would come from...you have to pack your axle vearings with grease or they will burn up. I have the "Green" sealed bearings anyways...not that they are worth it. I also have a vibration that starts about 75-80 mph. I think it is in the rear end differential but am just trying a different set of wheels and tires this weekend? We'll see? I wonder if it could be the clutch plates in the sure grip being stuck together from sitting or something? When I push the car in neutral with the engine off, there is a clunking every revolution like something is sticking.
Re: 67 GTX that is bound and determin to be a vibrator [Re: wesgtx440] #1325830
10/25/12 02:50 PM
10/25/12 02:50 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
As JD sez sorry, no.. The bearing is sealed from gear oil intrusion & should be packed in bearing grease...
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325831
10/25/12 03:25 PM
10/25/12 03:25 PM
Canfield,Ohio,USA
gassy66 Offline
gassy66  Offline
Canfield,Ohio,USA
Is the rear end a "sure grip" ?? If so, I'm suggesting that the differential be pulled out and examined.. I have a hunch that the clutch pack
may be the source of the vibes...
Re: 67 GTX that is bound and determin to be a vibrator [Re: gassy66] #1325832
10/25/12 03:40 PM
10/25/12 03:40 PM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
I stand corrected. It has been a few years since I did one and I had myself convinced that they were lubed by the gear oil. Still something to check though.
Re: 67 GTX that is bound and determin to be a vibrator [Re: gassy66] #1325833
10/26/12 01:14 AM
10/26/12 01:14 AM
fresno ca
mikeysmopars Offline
fresno ca
A worn out sure grip shouldn't cause a vibration in my opinion even at speed but i have seen them chatter & try to lock up when turning if they didn't put in sure grip lube along with gear oil. If its an automatic a converter could be the culprit.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 67 GTX that is bound and determin to be a vibrator [Re: mikeysmopars] #1325834
10/26/12 02:00 AM
10/26/12 02:00 AM
Warrenton, VA
Warrenton, VA
How can the convertor be the cause? I have a new Turbo Action convertor with 160 miles on it and the motor is internally balanced. Itfeelsluke a vibration in the rear end?
Re: 67 GTX that is bound and determin to be a vibrator [Re: RoadRunnerJD] #1325835
10/26/12 10:29 AM
10/26/12 10:29 AM
The GTX is a stripper version with column shift manual steering and brakes and coded for an open 3.23. We have even changed out the complete chunk with one from a low milage c body and same problem persist. We have considered the driveline angle but why would it change setting over the winter? Only reason i could come up with is leaf springs settled a little bit but seems unlikely. I really appriciate the replies here guys!
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325836
10/26/12 10:32 AM
10/26/12 10:32 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Could be as simple as a u-joint or an out of balance drive shaft or bad trans or engine mount, or even a tail shaft bearing in the trans.
Re: 67 GTX that is bound and determin to be a vibrator [Re: ScottSmith_Harms] #1325837
10/26/12 10:42 AM
10/26/12 10:42 AM
we have had drive shaft checked and balanced, new u joints, new tail shaft housiing bushing, all new mounts.
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325838
10/26/12 10:43 AM
10/26/12 10:43 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, but "All New" doesn't always mean all good. you might want to double check.
Re: 67 GTX that is bound and determin to be a vibrator [Re: GI Moparman] #1325839
10/26/12 04:27 PM
10/26/12 04:27 PM
Warrenton, VA
Warrenton, VA
I would change the U- joints
