950 too big? #1325535
10/24/12 10:02 PM
10/24/12 10:02 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Im putting together a stock stroke, KB 107 pistoned 360 that fell into my lap until I complete my r3. I will be using my "stage 3~ish Brodix heads that flow 290 at .600. Hooker super comps, all steel Abody, 4:56 geared, 4400 converter, victor manifold and custom cam specs are in the attachment because Im that lazy tonight. I have my 950 profom off my old 4" motor and wondering if it will be less than ideal. I would just buy a 750 but Id rather spend it on a dommy for the bigger motor. Can this carb get by without killing the combo?
Re: 950 too big? [Re: Hot 340] #1325536
10/24/12 10:10 PM
10/24/12 10:10 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
i had my 950hp on my 340 stock stroke motor ran pretty good.. just couldnt get the car to 60' cause i was to lazy to work on the chassis..1.67 best i had ran 7.40 at 90mph in the 1/8 mile all steel car..
Re: 950 too big? [Re: Hot 340] #1325537
10/24/12 10:26 PM
10/24/12 10:26 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
The 950 will work good use it then just buy your dominator for your good motor when done.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: 950 too big? [Re: bdaz smblk] #1325538
10/24/12 10:40 PM
10/24/12 10:40 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 950 too big? [Re: Triple Threat] #1325539
10/25/12 08:54 PM
10/25/12 08:54 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thank you guys..we'll run it. It seemed to take some response out of my stroker, so I figured with the shorter stroke maybe worse..
Re: 950 too big? [Re: Hot 340] #1325540
10/25/12 09:07 PM
10/25/12 09:07 PM
The Holley 950HP do not flow 950CFM at the standards used to flow test carbs I'm sure the after market 950 carbs. do flow 950 CFM
Re: 950 too big? [Re: Cab_Burge] #1325541
10/25/12 09:10 PM
10/25/12 09:10 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
This one is a proform 950
Re: 950 too big? [Re: Hot 340] #1325542
10/25/12 10:17 PM
10/25/12 10:17 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
The ProForm950 has the larger venturi than the old Holley HP950. I have an old HP950, and a Quickfuel950 which is what Proform imitated . Throttle response is much better with the smaller one as it has similar venturi sizing as an older 750.
On a lower rpm engine,the large venturi is harder to get a decent fuel curve established.
