Rotating assembly turning torque #1325417
10/24/12 02:03 PM
10/24/12 02:03 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
This is a FWIW, since I'm not sure what sort of interest it may have.
Anyway, I put my new digital torque wrench on the crank of the 452 yesterday after doing the final "torque + angle" routine on the rod bolts and found the turning torque of the assembly "as is" (light lube on the piston assemblies and bearing lube on the crank & rod journals) measured 17-18#s.
I've read somewhere that a typical street build is 25-30#s and "real" race engines can be down closer to (or in the?) single-digits, so I think this looks fairly low-friction for a street/strip build. I've never actually checked this before on my own engines, so I don't have any point of comparison, unfortunately.
Re: Rotating assembly turning torque [Re: BradH] #1325418
10/24/12 02:35 PM
10/24/12 02:35 PM
Az
Crizila Offline
Crizila  Offline
Az
Just finished a 408 sm blk build using 1/16" rings and I came up with a torque reading of 25 ft lbs. Bearing clearances were a little on the tight side. Piston to wall clearance was .008". ( forged "Icon" blower pistons).
Fastest 300
Re: Rotating assembly turning torque [Re: BradH] #1325419
10/24/12 02:35 PM
10/24/12 02:35 PM
Delray beach, Florida
P
Performance Only Offline
P
That's a good number for rotating torque. What was the breakaway torque reading?
machine shop owner and engine builder
Re: Rotating assembly turning torque [Re: Performance Only] #1325420
10/24/12 02:52 PM
10/24/12 02:52 PM
BradH Offline OP
BradH  Offline OP
I set the target torque # for the wrench to 30#s and started to pull slowly & steadily on it... it "flashed" to 18#s and then looked like it settled to about 17#s for the rest of the pull. The max torque # displayed was the initial 18#.
Re: Rotating assembly turning torque [Re: BradH] #1325421
10/24/12 02:54 PM
10/24/12 02:54 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
mine 19
Re: Rotating assembly turning torque [Re: sixpackgut] #1325422
10/24/12 03:12 PM
10/24/12 03:12 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
My last one - 16#.
Re: Rotating assembly turning torque [Re: 64Post] #1325423
10/24/12 03:16 PM
10/24/12 03:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
my 408 is 20#
Re: Rotating assembly turning torque [Re: mopar dave] #1325424
10/24/12 03:48 PM
10/24/12 03:48 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Will that number be any different once the rings are seated?
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Rotating assembly turning torque [Re: mopar dave] #1325425
10/24/12 03:49 PM
10/24/12 03:49 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
I usually shoot for under 20 on a steel rod motor with 1/16 compression rings. 16-18 is pretty typical. Aluminum rod motors in my experience seem to have a bit more initial drag. You can tell a lot about the motor just by setting the crank and torquing the mains. Line hones are HP.
Drives me nuts when guys insist on main studs and then want to skimp on a hone.
WIZE
In Car:
Re: Rotating assembly turning torque [Re: BradH] #1325426
10/24/12 05:07 PM
10/24/12 05:07 PM
The cylinder wall finish, the ring width and tension and the lube used will affect the breakaway and rotational torque. Dick Landy told me years ago to use 20 to 23 lbs break away and 16 to 18 lbs. rotational as a way of measureing a good job I have a SB Chevy pump gas blower motor with 5/64, 5/64 compression rings and 3/16 standard tension oil rings in the shop now, that rascal is not as easy to turn as the bigger bore Mopar motors with 1/16,1/16, 3/16 oil ring with standard tension I did a bracket race motor last year that had 1.5MM,1.5MM,compression rings and 3MM oil ring, it was real easy to turn, I should have checked it and written it down It was noticably easier to assemble and turn over My next race motor may have thinner rings than that
Re: Rotating assembly turning torque [Re: BradH] #1325427
10/24/12 05:33 PM
10/24/12 05:33 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
u should use a beam type torque wrench to check turning torque
Re: Rotating assembly turning torque [Re: rickraw] #1325428
10/24/12 08:31 PM
10/24/12 08:31 PM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: Rotating assembly turning torque [Re: Crizila] #1325429
10/25/12 12:06 AM
10/25/12 12:06 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
hi, a beam torque wrench will give you truer results. as for rotational torque, my 340, 5# to rotate, metric rings in motor.
Re: Rotating assembly turning torque [Re: Dap] #1325430
10/25/12 09:22 AM
10/25/12 09:22 AM
oberlin, Ohio
Rapid340 Offline
Rapid340  Offline
oberlin, Ohio
Yes, it will be smaller to varying degrees depending on cylinder wall finish.
1971 Factory Appearing Duster 340 11.000 @ 122 mph
Re: Rotating assembly turning torque [Re: perfmachst] #1325431
10/25/12 11:49 AM
10/25/12 11:49 AM
Az
Crizila Offline
Crizila  Offline
Az
5 pounds????
Fastest 300
Re: Rotating assembly turning torque [Re: rickraw] #1325432
10/25/12 11:58 AM
10/25/12 11:58 AM
The Great White North
RAMM Offline
RAMM  Offline
I agree although a Snap-On dial type is easier to read while in motion. That being said 17-18 lbs for a big block with that stroke is fairly typical in my experience. Working on a 705ci Chevy and it is alot more than that with a 5.3" stroke I can tell you. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Rotating assembly turning torque [Re: RAMM] #1325433
10/25/12 05:18 PM
10/25/12 05:18 PM
BradH Offline OP
BradH  Offline OP
... 17-18 lbs for a big block with that stroke is fairly typical in my experience.
At least it's good to know I haven't effed it up...
FWIW, this is a stock-stroke 440 + .060" w/ ~ .006" piston clearance, just under .003" rod & main clearance, conventional 1st rings, Napier 2nds and 18# oils (according to Total Seal).
My last build used their (TS) "gapless" top rings, RBT 2nds and 23# oils, so this "should" reduce the drag somewhat while still (hopefully) keeping oiling under control.
