Rotating assembly turning torque
#1325417
10/24/12 02:03 PM
10/24/12 02:03 PM
BradH
This is a FWIW, since I'm not sure what sort of interest it may have. Anyway, I put my new digital torque wrench on the crank of the 452 yesterday after doing the final "torque + angle" routine on the rod bolts and found the turning torque of the assembly "as is" (light lube on the piston assemblies and bearing lube on the crank & rod journals) measured 17-18#s. I've read somewhere that a typical street build is 25-30#s and "real" race engines can be down closer to (or in the?) single-digits, so I think this looks fairly low-friction for a street/strip build. I've never actually checked this before on my own engines, so I don't have any point of comparison, unfortunately.
Re: Rotating assembly turning torque
[Re: BradH]
#1325418
10/24/12 02:35 PM
10/24/12 02:35 PM
Posts: 7,506 Az
Crizila
Az
Just finished a 408 sm blk build using 1/16" rings and I came up with a torque reading of 25 ft lbs. Bearing clearances were a little on the tight side. Piston to wall clearance was .008". ( forged "Icon" blower pistons).
Fastest 300
[Re: Performance Only]
#1325420
10/24/12 02:52 PM
10/24/12 02:52 PM
BradH
That's a good number for rotating torque. What was the breakaway torque reading?
I set the target torque # for the wrench to 30#s and started to pull slowly & steadily on it... it "flashed" to 18#s and then looked like it settled to about 17#s for the rest of the pull. The max torque # displayed was the initial 18#.
[Re: mopar dave]
#1325424
10/24/12 03:48 PM
10/24/12 03:48 PM
Posts: 1,855 Staten Island N.Y.
Dap
Staten Island N.Y.
Will that number be any different once the rings are seated?
PRH446 10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
[Re: BradH]
#1325426
10/24/12 05:07 PM
10/24/12 05:07 PM
Posts: 43,296 Bend,OR USA
Cab_Burge
The cylinder wall finish, the ring width and tension and the lube used will affect the breakaway and rotational torque. Dick Landy told me years ago to use 20 to 23 lbs break away and 16 to 18 lbs. rotational as a way of measureing a good job I have a SB Chevy pump gas blower motor with 5/64, 5/64 compression rings and 3/16 standard tension oil rings in the shop now, that rascal is not as easy to turn as the bigger bore Mopar motors with 1/16,1/16, 3/16 oil ring with standard tension I did a bracket race motor last year that had 1.5MM,1.5MM,compression rings and 3MM oil ring, it was real easy to turn, I should have checked it and written it down It was noticably easier to assemble and turn over My next race motor may have thinner rings than that
[Re: RAMM]
#1325433
10/25/12 05:18 PM
10/25/12 05:18 PM
BradH
... 17-18 lbs for a big block with that stroke is fairly typical in my experience.
At least it's good to know I haven't effed it up...
FWIW, this is a stock-stroke 440 + .060" w/ ~ .006" piston clearance, just under .003" rod & main clearance, conventional 1st rings, Napier 2nds and 18# oils (according to Total Seal).
My last build used their (TS) "gapless" top rings, RBT 2nds and 23# oils, so this "should" reduce the drag somewhat while still (hopefully) keeping oiling under control.
