Page 1 of 3 1 2 3
1970 Road Runner trunk and quarter replacement #1325209
10/23/12 10:51 PM
10/23/12 10:51 PM
Granite City IL.
Jimster70 Offline OP
Granite City IL.
70 Road Runner surgical trunk removal. Lots of spot welds!!!!!!!!!!
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325210
10/23/12 10:53 PM
10/23/12 10:53 PM
Granite City IL.
Granite City IL.
Was able to save the center brace.
I used a 1/8 inch drill bit and drilled a pilot hole in the center of all of the spot welds. Then a 1/2 inch rotabroach sheetmetal hole cutter and attempted to just go though the upper skin. When using the rotabroach cutter, the chips were clean and then you can feel the cutter when it goes through and starts to touch the frame rail. You will sometimes see a puff of dirt or rust powder when it breaks though. The cutter will last longer if you spray a little wd40 or cutting oil on the cutter every other hole or so. The pilot hole will be welded up later when you replace the pan.
I hope this helps anyone thinking about this project.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325211
10/23/12 10:55 PM
10/23/12 10:55 PM
Granite City IL.
Granite City IL.
peeled back abit I used a 4 1/2 inch angle grinder with a .040 metal cutting wheel for the pan cutting.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325212
10/23/12 10:56 PM
10/23/12 10:56 PM
Granite City IL.
Granite City IL.
frame rails
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325213
10/23/12 10:58 PM
10/23/12 10:58 PM
Granite City IL.
Granite City IL.
most of it removed
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325214
10/23/12 11:01 PM
10/23/12 11:01 PM
Granite City IL.
Granite City IL.
new panel for replacement
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325215
10/24/12 10:39 PM
10/24/12 10:39 PM
WI
W
wannadrag Offline
wannadrag  Offline
W
WI
Does a one piece fit through the trunk opening?
Re: 1970 Road Runner trunk and quarter replacement [Re: wannadrag] #1325216
10/25/12 01:14 AM
10/25/12 01:14 AM
Granite City IL.
Granite City IL.
I dont think so. I will get a chance to try later tonight. I thought it would fit with the quarter off but the wheelhouse is in the way. May need to cut it in half and butt weld it after all.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325217
10/26/12 07:50 PM
10/26/12 07:50 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
don't be stingy...lets see the rest of the car!
1981 Dodge D150 360 auto
Re: 1970 Road Runner trunk and quarter replacement [Re: basketcase] #1325218
10/28/12 06:04 PM
10/28/12 06:04 PM
Granite City IL.
Granite City IL.
Heres a few before pictures
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325219
10/28/12 06:05 PM
10/28/12 06:05 PM
Granite City IL.
Granite City IL.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325220
10/28/12 06:06 PM
10/28/12 06:06 PM
Granite City IL.
Granite City IL.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325221
10/28/12 06:06 PM
10/28/12 06:06 PM
Granite City IL.
Granite City IL.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325222
11/02/12 09:46 PM
11/02/12 09:46 PM
daytona kid Offline
daytona kid  Offline
I had a 70 beeper that same color. Friends kidded me that it was military green. It had faded profusely.
Thnx for the info, Keep the pics and tips coming. Let us see all your progress as you go. I'm about to do the pans in my charger.
Nice car
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325223
11/03/12 11:48 AM
11/03/12 11:48 AM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
From experience, don't cut the one piece floor pan. Carefully drill the spot welds on the tail panel and remove it. The trunk floor will slide right in that way. You can re use your original tail panel or replace it with new. I'm still doing a 70 Charger the same way. New quarters, wheel houses, trunk floor and extensions, tail panel and rear valance. I counted the spot welds in the trunk floor once...almost 400 but the AMD panel fit very well.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325224
11/04/12 07:28 PM
11/04/12 07:28 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
great runner! are you keeping it green? I'm getting my '69 put back to F8
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325225
11/14/12 09:11 PM
11/14/12 09:11 PM
daytona kid Offline
daytona kid  Offline
Where did you get your rota-broach hole cutter?
I am having a little trouble finding and figuring out just what I need.
Re: 1970 Road Runner trunk and quarter replacement [Re: daytona kid] #1325226
11/15/12 12:37 AM
11/15/12 12:37 AM
Granite City IL.
Granite City IL.
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325227
11/15/12 12:40 AM
11/15/12 12:40 AM
Granite City IL.
Granite City IL.
Ebay has them also
here is a link to another brand, Jancy slug cutters that work well
web page
Re: 1970 Road Runner trunk and quarter replacement [Re: Jimster70] #1325228
11/18/12 10:23 PM
11/18/12 10:23 PM
daytona kid Offline
daytona kid  Offline
Thnx, They are on the way. Keep us posted on your progress. More pics.
Page 1 of 3 1 2 3
