Re: 1970 Road Runner trunk and quarter replacement
[Re: Jimster70]
#1325210
10/23/12 10:53 PM
10/23/12 10:53 PM
Posts: 86 Granite City IL.
Jimster70
Granite City IL.
Was able to save the center brace. I used a 1/8 inch drill bit and drilled a pilot hole in the center of all of the spot welds. Then a 1/2 inch rotabroach sheetmetal hole cutter and attempted to just go though the upper skin. When using the rotabroach cutter, the chips were clean and then you can feel the cutter when it goes through and starts to touch the frame rail. You will sometimes see a puff of dirt or rust powder when it breaks though. The cutter will last longer if you spray a little wd40 or cutting oil on the cutter every other hole or so. The pilot hole will be welded up later when you replace the pan. I hope this helps anyone thinking about this project.
[Re: Jimster70]
#1325211
10/23/12 10:55 PM
10/23/12 10:55 PM
Jimster70
Granite City IL.
peeled back abit I used a 4 1/2 inch angle grinder with a .040 metal cutting wheel for the pan cutting.
[Re: wannadrag]
#1325216
10/25/12 01:14 AM
10/25/12 01:14 AM
Jimster70
Granite City IL.
I dont think so. I will get a chance to try later tonight. I thought it would fit with the quarter off but the wheelhouse is in the way. May need to cut it in half and butt weld it after all.
[Re: Jimster70]
#1325222
11/02/12 09:46 PM
11/02/12 09:46 PM
daytona kid
I had a 70 beeper that same color. Friends kidded me that it was military green. It had faded profusely. Thnx for the info, Keep the pics and tips coming. Let us see all your progress as you go. I'm about to do the pans in my charger. Nice car
[Re: Jimster70]
#1325223
11/03/12 11:48 AM
11/03/12 11:48 AM
Posts: 6,427 S.E. Missouri
AeroMonte
S.E. Missouri
From experience, don't cut the one piece floor pan. Carefully drill the spot welds on the tail panel and remove it. The trunk floor will slide right in that way. You can re use your original tail panel or replace it with new. I'm still doing a 70 Charger the same way. New quarters, wheel houses, trunk floor and extensions, tail panel and rear valance. I counted the spot welds in the trunk floor once...almost 400 but the AMD panel fit very well.
[Re: Jimster70]
#1325224
11/04/12 07:28 PM
11/04/12 07:28 PM
Posts: 7,831 east side of Ohio
basketcase
east side of Ohio
great runner! are you keeping it green? I'm getting my '69 put back to F8
1981 Dodge D150 360 auto
[Re: Jimster70]
#1325233
02/26/13 05:07 PM
02/26/13 05:07 PM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
Thanks for the info-I just ordered a set from the same link! I did it the hard way 2 years ago with my 70 Barracuda. I spent HOURS and HOURS grinding through each weld...never again thanks to you! Dod you have an estimate of how long it took you to cut all the trunk floor welds and remove the trunk pan?
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: Jimster70]
#1325234
02/26/13 09:42 PM
02/26/13 09:42 PM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
Looking good. I am just beginning the tear down of my 68 Road Runner. The driver's side was hit hard and repaired with a sledge hammer and a couple of gallons of bondo. I have had to remove the inner structure and door jamb. I am onto the trunk in the next few weeks.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Jimster70]
#1325242
02/27/13 02:59 PM
02/27/13 02:59 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Now what to do with this sunroof? Volvo swap or plug it? I am on the fence about this roof
Pencil me in for 'plug it'...
[Re: Jimster70]
#1325246
02/28/13 01:02 AM
02/28/13 01:02 AM
Posts: 4,872 connecticut
pnypwr
connecticut
when its metal your not gonna use i tend to take the air chisel to the spot welds...you wont did into the rail...saves a ton of time over drilling the welds. if you plan on reusing a panel a 1/2 roto is humongas and your just filling and filling for reuse i like 3/8 but fresh metal ill drill a 1/4 in hole to plug weld. i need to get back on my 68, your cars alot more solid than mine however, i woulda loved to get away with cheater skins.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
[Re: Jimster70]
#1325248
02/28/13 02:30 PM
02/28/13 02:30 PM
Posts: 1,377 Back In Iowa
belv2vert66
Back In Iowa
rr4
Awesome work ! Just out of curiousity .....Does anyone know if you can split the full trunk floor right over where the frame rail is and have it still fit through the trunk opening ? It would save having to "finish" the bottom of the trunk floor as the frame rail would hide it
[Re: belv2vert66]
#1325249
02/28/13 04:02 PM
02/28/13 04:02 PM
Posts: 1,281 WI
wannadrag
WI
rr4
Gas tank hides most of the center splice so who the heck will ever see it.
[Re: belv2vert66]
#1325250
03/01/13 03:22 AM
03/01/13 03:22 AM
Posts: 1,528 Southeast PA
5wndwcpe
Southeast PA
I did that with mine and it worked great. The only caveat is it's on a '68 convertible. The trunk floor is the same but I believe the trunk hinge mounts are in a slightly different location.
1968 GTX hardtop 1968 Sport Satellite Convertible 383/4spd 1933 Plymouth coupe 2002 Ram 2500 oil burner 4x4 2015 Grand Cherokee 2013 Challenger 1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
[Re: Jimster70]
#1325254
03/06/13 08:23 AM
03/06/13 08:23 AM
moparpollack
Lil Herman
Lil Herman
85086
Supposedly a Volvo sun roof is close to a factory sunroof. If it were mine I would just patch the hole.
