6.1 in a "70 Cuda #1325129
10/23/12 08:33 PM
10/23/12 08:33 PM
Jax.Jags Offline OP
Jax.Jags  Offline OP
Ok.I finally did it. Bought the engine I've been wanting for 5+ years now. I've read the sticky's and most of the posts on this board. All have been great but I still have a million questions, so I hope everyone will bear with me. First, has anyone put a A518(46RH) behind a 6.1? To me, it seems like the easiest way to get OD. Is there anyway to get around the $700 TTI header situation? I've read about some manifolds that will work, but all threads are incomplete. I'll start with those; have a few thousand more, but I'll start there. Any help is much appreciated.
Re: 6.1 in a "70 Cuda [Re: Jax.Jags] #1325130
10/23/12 08:36 PM
10/23/12 08:36 PM
GA
roadrunninMark Offline
GA
watching this, I will be going with A518 as well. Jax, where did you find a 6.1? Please make a thread of your build!
Re: 6.1 in a "70 Cuda [Re: roadrunninMark] #1325131
10/23/12 08:39 PM
10/23/12 08:39 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
I read somewhere Jeep GC manifolds work in an A-Body (I think the crate motor documentation), I went the TTI route.
-Daty
Re: 6.1 in a "70 Cuda [Re: Daty Rogers] #1325132
10/23/12 09:18 PM
10/23/12 09:18 PM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
FWIW, the January 2013 of Mopar Muscle has an article for putting a 904 behind a late model Hemi. "New Old School" by Dave Young p20
Common sense is a flower that does not grow in everybody's garden
Re: 6.1 in a "70 Cuda [Re: roadrunninMark] #1325133
10/23/12 09:18 PM
10/23/12 09:18 PM
Jax.Jags Offline OP
Jax.Jags  Offline OP
Local recycler; there is one on ebay now for CHEAP. All it took was for me to jump and find out I could have got it cheaper. Still got a good deal I think. It's out of a 300. It's just sitting in my garage...haven't even pulled the pan yet! I will do a build thread for sure. I'll be sure to leave out all the bonehead mistakes I'm going to make...unless it may help. The MM should be a good read, but I would really like to have OD. When I found out you can trim a A518 housing without hacking the car's tunnel, I just thought it would be having your cake a eating it too.
Re: 6.1 in a "70 Cuda [Re: Jax.Jags] #1325134
10/23/12 09:27 PM
10/23/12 09:27 PM
Texas
Daty Rogers Offline
Daty Rogers  Offline
Texas
https://board.moparts.org/ubbthreads/favl...amp;postmarker= here's my thread, granted a 67 BCuda, but the princible is the same, please post your flubs too, those can be more informative, had plenty on mine.
-Daty
Re: 6.1 in a "70 Cuda [Re: Daty Rogers] #1325135
10/24/12 02:11 AM
10/24/12 02:11 AM
GA
GA
Jax- I have been looking lately, looking on ebay right now. I am not seeing one cheap, the lowest I see is $6,200. You have a link??
Daty - I ll check out your thread..
Here is 808CUDA's build thread to help also: https://board.moparts.org/ubbthreads/show...e=2#Post3930520
Re: 6.1 in a "70 Cuda [Re: Ron_M] #1325136
10/24/12 08:17 AM
10/24/12 08:17 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Why the hell would you do that...????????
While you're at it, swap the alternator for a generator, maybe find a way to install points-ignition on it...??? Even the 518 sounds dated for this idea. Whats wrong with the auto they come with? or an OD stick...???
Re: 6.1 in a "70 Cuda [Re: Pale_Roader] #1325137
10/24/12 09:01 AM
10/24/12 09:01 AM
NY usa
540challenger Offline
NY usa
Nothing wrong with the "newwer transmissions but If you run a stand alone system for the hemi, it won't work b/c you need the factory computer to run it, it is cheaper and easier to run a 727 or 904 plus you would need to rework the floors and tranmission tunnel, cross member etc to get it to fit they are big!!
Re: 6.1 in a "70 Cuda [Re: Pale_Roader] #1325138
10/24/12 05:32 PM
10/24/12 05:32 PM
Jax.Jags Offline OP
Jax.Jags  Offline OP
Definitely want OD for the swap; the reason I am leaning towards the A518 is because of the cost and the fitment. Have you priced the cost to run a NAG transmission? It ain't pretty. Plus if I can avoid cutting up my car, I'm all for it.
Re: 6.1 in a "70 Cuda [Re: Pale_Roader] #1325139
10/24/12 06:19 PM
10/24/12 06:19 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
Funny stuff here.
Re: 6.1 in a "70 Cuda [Re: Jjs72D] #1325140
10/24/12 06:32 PM
10/24/12 06:32 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
There is going to be an affordable controller for the NAG1 soon, it will pick up speed from the driveshaft instead of the rear hub on the IRS in the original application.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 6.1 in a "70 Cuda [Re: AlexP] #1325141
10/30/12 12:12 AM
10/30/12 12:12 AM
mississippi
lostdog Offline
lostdog  Offline
mississippi
Alex, do you know if this controller will allow flexibility for cam change?
