B1 pso heads #1325071
10/23/12 07:19 PM
10/23/12 07:19 PM
Newfoundland,Canada
avenger572 Offline OP
Newfoundland,Canada
Any know how much higher pso heads and intake ( single 4) would be . Im currently using 572-13 and single 4 . Need good measurements dont have a lot of room.
Re: B1 pso heads [Re: avenger572] #1325072
10/23/12 09:00 PM
10/23/12 09:00 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
How big of improvement over 572-13 heads are pso's?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: B1 pso heads [Re: 1967dartgt] #1325073
10/23/12 09:29 PM
10/23/12 09:29 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
The last run of B-1 PSO castings we did were about 60-70 CFM better on our flow bench, Taller valve spring height for more cam lift and more runner volume. The casting is the same outside as a B-1 orginal and intake bolt pattern is the same but does have a rasied port on ours.
Re: B1 pso heads [Re: avenger572] #1325074
10/24/12 04:13 PM
10/24/12 04:13 PM
gregsdart Offline
gregsdart  Offline
The PSO heads should be worth considerable hp, based on a lot more flow plus the port cross section area to feed the motor. If they flow 60 to 70 cfm more than the 572 heads, then my guess is they would gain a minimum of 120 to 150 hp over the 572s if you put the right parts in the motor to support the heads. I was told by a pretty sharp guy (ported my heads) that a good head should be able to make close to 2.45 hp per cfm of flow. So if those PSOs flow 470, they should be able to produce 1150 hp if the motor is built right. BestMachine Can you post some info on thier potential?
Re: B1 pso heads [Re: PETE@BESTMACHINE] #1325075
10/24/12 04:54 PM
10/24/12 04:54 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
I think the OP is looking for a physical height difference between the two due to limited space.
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: B1 pso heads [Re: avenger572] #1325076
10/24/12 05:53 PM
10/24/12 05:53 PM
Newfoundland,Canada
Newfoundland,Canada
Need the measurement from valley tray end rails to top of intake manifold
Re: B1 pso heads [Re: avenger572] #1325077
10/24/12 06:56 PM
10/24/12 06:56 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Would it help if I did this on my B1 originals for you? I just got back from the track an hour ago, and unloaded my car, It is in the shop now. Not sure if it is the same as the PSO
Re: B1 pso heads [Re: avenger572] #1325078
10/24/12 06:56 PM
10/24/12 06:56 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Curious about this too, also interested to see if the exhaust manifold bolt pattern is the same or near.
Re: B1 pso heads [Re: 1967dartgt] #1325079
10/24/12 09:14 PM
10/24/12 09:14 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: B1 pso heads [Re: fishy340] #1325080
10/24/12 09:18 PM
10/24/12 09:18 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
i needed a cigarette after i saw that motor up close..lol
Re: B1 pso heads [Re: fishy340] #1325081
10/24/12 09:32 PM
10/24/12 09:32 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i want a PSO engine so bad it hurts
Re: B1 pso heads [Re: sixpackgut] #1325082
10/25/12 12:36 AM
10/25/12 12:36 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
What do pso's run $$?
Re: B1 pso heads [Re: 1967dartgt] #1325083
10/27/12 10:06 AM
10/27/12 10:06 AM
Ky
moparmafia Offline
moparmafia  Offline
Ky
What is the price of pso heads and where can you get them?
Re: B1 pso heads [Re: sixpackgut] #1325084
10/27/12 10:09 AM
10/27/12 10:09 AM
gregsdart Offline
gregsdart  Offline
me to. I just need to go buy a lottery ticket. If the wrong guy gets in, my social security might go south, and I won't be able to run it!
Re: B1 pso heads [Re: gregsdart] #1325085
10/27/12 11:15 AM
10/27/12 11:15 AM
SD USA
neonic Offline
neonic  Offline
SD USA
I talked with Koffles a couple of months ago about PSO heads.
Scott said $2600 for castings but Brodix won't cast until they have 5 sets. Scott also said the MC will flow within 20 cfm of PSO heads and use more standard valve train.
Re: B1 pso heads [Re: neonic] #1325086
10/27/12 07:52 PM
10/27/12 07:52 PM
Ky
moparmafia Offline
moparmafia  Offline
Ky
Is Koffels the only one that can get these heads? I know best machine is not able to get them. Somewhere around spring time I would like to get a set of the pso or maybe the mc heads.
Re: B1 pso heads [Re: avenger572] #1325087
10/28/12 11:51 AM
10/28/12 11:51 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The PSO starts its life as the same casting as all other B1 Original Heads do. They are very raw castings but the outside dimensions are the exact same as the b1 originals
Re: B1 pso heads [Re: joshking440] #1325088
10/28/12 11:52 AM
10/28/12 11:52 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
The castings are all bought from Koffel regardless of who is selling them
Re: B1 pso heads [Re: joshking440] #1325089
10/28/12 12:13 PM
10/28/12 12:13 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
My block was milled .011 and my b1's milled .100, but I will go measure from the tray to the top of the intake for you. I will be out in my shop in a few minutes
Re: B1 pso heads [Re: Mopar-Al] #1325090
10/28/12 01:14 PM
10/28/12 01:14 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
From the TOP of my B1 valley tray to the top of the intake is close to 9 5/16 The valley plate is around 180 thou thick, then, my heads are milled to 65cc which was another 100 thou, and the block milled 11 thou. Also my head gaskets are 40 thou. you may be best to base your figure at 9.750 to be close. Mine is around 9.644, i'm useing 2 sets of b1 intake gaskets at .030 a thick for the spacers on the rb block.
