Page 1 of 3 1 2 3
440 Tunnel Rams, Which one works best? #1325005
10/23/12 05:24 PM
10/23/12 05:24 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
I ran an "Offenhauser" tunnel ram on my car with a set of 660 Holleys for a bit before switching over to the M1 Tunnel ram. The M1 ran leaps and bounds better than the Offy. Is the M1 that much better than Offy or is the Offy just for bigger motors or what? My combo is a stock 73 440 bottom end, 7.8:1 compression, 295/557 Purple cam, 906 heads w/template porting, 1 7/8" headers. 3500 stall, 4:30 gears and 3760 w/driver. 12.30's @ 109 was it's best with the M1 tunnel ram. Should I give the OFFY another chance or is it always going to be a 2nd best?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325006
10/23/12 08:04 PM
10/23/12 08:04 PM
Canada
CrAzYMoPaRGuY Offline
Canada
M1 will outperform the Offy imo.
That's an odd combination! 12.30 isn't too shabby ?
CrAzYMoPaRGuY
Re: 440 Tunnel Rams, Which one works best? [Re: CrAzYMoPaRGuY] #1325007
10/23/12 08:17 PM
10/23/12 08:17 PM
Central NC
gch Offline
gch  Offline
Central NC
M1 or the weiand.Scrap that Offy or sell it to some nostalgia guys.
Re: 440 Tunnel Rams, Which one works best? [Re: gch] #1325008
10/24/12 01:15 PM
10/24/12 01:15 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Bump up your compression and put a pair of 750 double pumpers on it sideways, you'll love it then! Or for even more eye appeal, machine the top plate for the Dominator pattern and put on a pair of 750 Dominators.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: 440 Tunnel Rams, Which one works best? [Re: Slingshot383] #1325009
10/24/12 01:25 PM
10/24/12 01:25 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
is the offy 180 a low dual carb setup?
a member here, TJ Marcus has a very strong running 440 with the offy tunnel ram
I run a weiand and love it
Re: 440 Tunnel Rams, Which one works best? [Re: sixpackgut] #1325010
10/24/12 02:26 PM
10/24/12 02:26 PM
Tucson AZ,
Tucson AZ,
It's substantially taller than the M1 and looking at it I don't know why it didn't work better. I was wondering if maybe my motor is to mild to utilize the Offy as it was designed? All I know is when I put the M1 on it was the fastest the car had ever gone. Swap meet weekend is coming up and I was just trying to decide whether or not it was time to send that Offy to a new home.
As far as the carbs go I will be trying some 750's next. I am going to be bumping the compression up this winter with some stock 1969 pistons so I'll be anxious to see how much that helps as well. Gotta love budget motors.
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325011
10/24/12 02:46 PM
10/24/12 02:46 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
thats interesting but i find it a little hard to believe. what are the ET and MPH numbers between the 2 different intakes?
Re: 440 Tunnel Rams, Which one works best? [Re: sixpackgut] #1325012
10/24/12 03:25 PM
10/24/12 03:25 PM
Tucson AZ,
Tucson AZ,
EDIT: My Dad remembers the car would hardly even run right with the Offenhauser on it. I actually don't think it ever even went to the track with the Offenhauser on it the more I think about it. If I remember correctly it was through the recommendation of those on this site that I switch to the M1. Doing nothing more than switching to the M1 made the car run right which is also when it ran it's best ET when compared to the single plane. That Offy has been sitting on the shelf for years though as has the M1 now. With the addition of kids and a a lack of going racing I put a single plane back on the car for lowered maintenance during street use and down time for the last several years. Think it's worth another comparison before selling it?
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325013
10/24/12 07:19 PM
10/24/12 07:19 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
With your compression being 7.8 - 1 why would you think you need a tunnel ram and dual 660's?
Re: 440 Tunnel Rams, Which one works best? [Re: Mopar-Al] #1325014
10/24/12 07:33 PM
10/24/12 07:33 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
A buddy of mine bought a Dart a little while back. It's a back halfed 69. It came without an engine but with a Offy Tunnel Ram and two Holley 660's Another buddy of ours had an old 78 Monico in the field at his place. The 440 had been rebuilt for propane shortly before the tranny went and the previous owner did not want to fix it. We took out the motor, checked a couple of bearings, did a spray can rebuild. We added a Mopar 509 cam and a set of box stock Eddy RPM Heads. I am not sure what the compression is but if I remember correctly the pistons are .250 in the hole. So far that car has run 11.05 at 119. I am convinced some of the power is coming from the tunnel ram!
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: 440 Tunnel Rams, Which one works best? [Re: Mopar-Al] #1325015
10/24/12 07:34 PM
10/24/12 07:34 PM
Tucson AZ,
Tucson AZ,
I had them laying around, they look cool and it made the car over a tenth quicker....
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325016
10/24/12 07:37 PM
10/24/12 07:37 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
That's impressing for sure Especially at your weight
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325017
10/24/12 07:45 PM
10/24/12 07:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
something else was wrong like a vaccum leak. i would bet the offy is faster than the M1. I wouldn't sell it
Re: 440 Tunnel Rams, Which one works best? [Re: sixpackgut] #1325018
10/25/12 12:43 AM
10/25/12 12:43 AM
Tucson AZ,
Tucson AZ,
Okay, you win. I'll give it another shot. If it goes slower than the M1 though you owe me a set of intake gaskets.
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325019
10/25/12 01:03 AM
10/25/12 01:03 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
a tube of goo for the tin pan. your on
Re: 440 Tunnel Rams, Which one works best? [Re: MadMopars] #1325020
10/25/12 01:04 AM
10/25/12 01:04 AM
It's been shown in tests that the M1 and Weiand are far better than the offy.
Re: 440 Tunnel Rams, Which one works best? [Re: ] #1325021
10/25/12 02:27 AM
10/25/12 02:27 AM
Pa
W
W7_Scamp Offline
W7_Scamp  Offline
W
Pa
try the offy again I ran 600's vac sec carbs on a whyand tunnelram on a 440 w 9-1comp a 509 cam and home ported 906's w a 3500 stall and 3:23 gears in a bone stock 70 valiant it went 11.50s at 120 lots of fun at the track and the bar lol.
Re: 440 Tunnel Rams, Which one works best? [Re: W7_Scamp] #1325022
10/25/12 05:51 AM
10/25/12 05:51 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
I miss my ram. but I will buy another one
Re: 440 Tunnel Rams, Which one works best? [Re: ] #1325023
10/25/12 09:42 AM
10/25/12 09:42 AM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
if you look at the test you speak off, it wasn't a fair test
Re: 440 Tunnel Rams, Which one works best? [Re: sixpackgut] #1325024
10/25/12 12:16 PM
10/25/12 12:16 PM
Cincinnati, Ohio
d7cook Offline
d7cook  Offline
Cincinnati, Ohio
I've had an Offy 360 tunnel ram for years. It has two Holley 650 carbs off a 350HP 68 Chrysler 440. For some reason that intake/carb combination has been the fastest intake I've put on just about anything from bone stock 440's to my old 10 second Dart. I'd never even change jetting moving it from motor to motor. I tested it back to back on my Dart with an M1 tunnel ram and the Offy was faster. It doesn't make sense but it is what it is.
1967 Coronet, 1989 Daytona tube chassis. Former cars, 66 Charger, 67 R/T, 69 Coronet, 67 Dart GT. -Banned for life from V8Buick.com-
Page 1 of 3 1 2 3
