Page 1 of 3 1 2 3
56 Dodge pickup front end #1324899
10/23/12 12:53 PM
10/23/12 12:53 PM
Newark,Ohio
kissmyaspen Offline OP
Newark,Ohio
Should be picking up a new project soon.. wondered if any of you guys have put a mustange II front end in one or what they are doing..
79 Dodge Aspen
12.265 at 109.75 MPH
67 Satellite NSS/E
11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street.
'07, '10, '12 Mopar Nats runner-up Street.
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324900
10/23/12 01:55 PM
10/23/12 01:55 PM
dogdays Offline
dogdays  Offline
Let me be the first to say Dakota front frame swap.
Actually, the MII works great, you can buy every part on the aftermarket and it is plenty strong enough for a street rod pickup. But the sentiment here is "keep it Mopar" so the Dak frame wins.
Fatman Fabrications is a good place to start on front ends.
R.
Re: 56 Dodge pickup front end [Re: dogdays] #1324901
10/23/12 02:53 PM
10/23/12 02:53 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
I'm lazy, when I did the frame all the following was done: brake lines, master cylinder, disc brakes, rack and pinion, bed floor, fuel tank, and steering shaft.
Here's what I had to fab up to make it work: mate the steering shaft, move the motor back and make mounts cab, engine and transmission, hang a brake pedal.
It time to make a build thread for my pick up.
Re: 56 Dodge pickup front end [Re: moparpollack] #1324902
10/23/12 03:47 PM
10/23/12 03:47 PM
85086
Lil Herman
Lil Herman
85086
current state
Re: 56 Dodge pickup front end [Re: moparpollack] #1324903
10/23/12 05:21 PM
10/23/12 05:21 PM
Newark,Ohio
Newark,Ohio
here is what im starting with
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324904
10/23/12 05:33 PM
10/23/12 05:33 PM
85086
Lil Herman
Lil Herman
85086
http://www.jalopyjournal.com/forum/showthread.php?t=710598&highlight=dakota+frame
Look halfway down the page at he red 56, the frame fits really good.
Re: 56 Dodge pickup front end [Re: moparpollack] #1324905
10/23/12 07:04 PM
10/23/12 07:04 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i would vote for the dakota too----mustangII is just an ok front end----most racers will admit that MII can be overwhelmed by horse power---even the MII guys upgrade to granada stuff which also ranks behind the dakota---another front and rear clip to consider for a hot rod is Jaguar MK6---they are bolt off/weld back on setups with superior brakes--and the jag rear is a dana 44 which you can buy anything for--just ask the jeep guys....bob
Re: 56 Dodge pickup front end [Re: moparpollack] #1324906
10/24/12 11:39 AM
10/24/12 11:39 AM
Newark,Ohio
Newark,Ohio
a full frame swap sounds like the way to go.. now to figure out what i will need.. reg cab short bed or long bed.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324907
10/25/12 03:31 AM
10/25/12 03:31 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
subsrcibed
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324908
10/25/12 06:40 PM
10/25/12 06:40 PM
85086
Lil Herman
Lil Herman
85086
Google search the Dakota wheel base and there should be three. Luckily the front tires to the back of the cab were the same on both trucks. The frames can be shortened but I didn't need to do that.
Re: 56 Dodge pickup front end [Re: moparpollack] #1324909
10/30/12 12:21 AM
10/30/12 12:21 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
somewhat on topic
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 56 Dodge pickup front end [Re: bigdad] #1324910
10/30/12 10:00 AM
10/30/12 10:00 AM
Newark,Ohio
Newark,Ohio
90% sure im going to do a full dakota frame swap.. got the truck on saturday so now time to dissasemble and rebuild. lots of work.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324911
10/30/12 07:25 PM
10/30/12 07:25 PM
85086
Lil Herman
Lil Herman
85086
If you don't have a lift and your friend does you have a new best friend.
The Trucks come apart easily but the bodies get in the way until you scrap the unneeded stuff.
Re: 56 Dodge pickup front end [Re: moparpollack] #1324912
10/30/12 10:24 PM
10/30/12 10:24 PM
Newark,Ohio
Newark,Ohio
We have 4 lifts .. Only bad part is that's how we make our money.. So have to find good stopping points when I do work on it at our shop. Like to get a lot of the big stuff done at the shop then do body work in my garage st home.
79 Dodge Aspen
67 Satellite NSS/E
11.83 @ 110
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324913
10/30/12 10:43 PM
10/30/12 10:43 PM
85086
Lil Herman
Lil Herman
85086
A newer Dakota looks funny on an old chassis DAMHIK. The guy at the scrap yard didn't like it either because they weren't bolted together.
My first measurement was from the back of the cab to the front wheel centerline. This helped me see how far back into the bed I was when moving cabs. Luckily on my Plymouth they were both 60". If possible work on the cab then the bed. My brakes and steering fell right into place afterward. If I had more info I could give it to you but there are quite a few pilot house builds on the HAMB.
Re: 56 Dodge pickup front end [Re: moparpollack] #1324914
10/30/12 11:00 PM
10/30/12 11:00 PM
Newark,Ohio
Newark,Ohio
Looking at a 93 dak. I figure get the cab on and center the front wheels in the wheel well and work from there.
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324915
10/30/12 11:21 PM
10/30/12 11:21 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
You may have seen my 57. It sets on the forward half of an 88 Dak frame and the rear half is shortened, narrowed and boxed 57. You can set the ride height by how far down over the frame that you set the body.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
Re: 56 Dodge pickup front end [Re: rattler] #1324916
10/30/12 11:25 PM
10/30/12 11:25 PM
Crofton, Ky.
rattler Offline
rattler  Offline
Crofton, Ky.
another
Re: 56 Dodge pickup front end [Re: kissmyaspen] #1324917
11/03/12 02:56 AM
11/03/12 02:56 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
post lots of pics please
2015 cherokee
2013 R/T classic
Re: 56 Dodge pickup front end [Re: fstfish66] #1324918
11/04/12 05:12 PM
11/04/12 05:12 PM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
03 and newer Crown Vic/Grand Marquis/Towncar. Front clip/engine cradle is bolted in with 4 bolts. IIRC the frame width is 34"
Kevin
Page 1 of 3 1 2 3
