56 Dodge pickup front end
#1324899
10/23/12 12:53 PM
10/23/12 12:53 PM
Posts: 1,413 Newark,Ohio
kissmyaspen
Newark,Ohio
Should be picking up a new project soon.. wondered if any of you guys have put a mustange II front end in one or what they are doing..
79 Dodge Aspen 12.265 at 109.75 MPH
67 Satellite NSS/E 11.83 @ 110
1968 Plymouth Road Runner 472 Hemi
3 time MOPAR NATIONALS CHAMP '03 FWD and '06 & '09 Street. '07, '10, '12 Mopar Nats runner-up Street.
Re: 56 Dodge pickup front end
[Re: dogdays]
#1324901
10/23/12 02:53 PM
10/23/12 02:53 PM
moparpollack
Lil Herman
Lil Herman
85086
I'm lazy, when I did the frame all the following was done: brake lines, master cylinder, disc brakes, rack and pinion, bed floor, fuel tank, and steering shaft.
Here's what I had to fab up to make it work: mate the steering shaft, move the motor back and make mounts cab, engine and transmission, hang a brake pedal.
It time to make a build thread for my pick up.
[Re: moparpollack]
#1324902
10/23/12 03:47 PM
10/23/12 03:47 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: moparpollack]
#1324903
10/23/12 05:21 PM
10/23/12 05:21 PM
kissmyaspen
Newark,Ohio
here is what im starting with
[Re: kissmyaspen]
#1324904
10/23/12 05:33 PM
10/23/12 05:33 PM
moparpollack
Lil Herman
Lil Herman
85086
[Re: kissmyaspen]
#1324908
10/25/12 06:40 PM
10/25/12 06:40 PM
moparpollack
Lil Herman
Lil Herman
85086
Google search the Dakota wheel base and there should be three. Luckily the front tires to the back of the cab were the same on both trucks. The frames can be shortened but I didn't need to do that.
[Re: kissmyaspen]
#1324911
10/30/12 07:25 PM
10/30/12 07:25 PM
moparpollack
Lil Herman
Lil Herman
85086
If you don't have a lift and your friend does you have a new best friend. The Trucks come apart easily but the bodies get in the way until you scrap the unneeded stuff.
[Re: kissmyaspen]
#1324913
10/30/12 10:43 PM
10/30/12 10:43 PM
moparpollack
Lil Herman
Lil Herman
85086
A newer Dakota looks funny on an old chassis DAMHIK. The guy at the scrap yard didn't like it either because they weren't bolted together.
My first measurement was from the back of the cab to the front wheel centerline. This helped me see how far back into the bed I was when moving cabs. Luckily on my Plymouth they were both 60". If possible work on the cab then the bed. My brakes and steering fell right into place afterward. If I had more info I could give it to you but there are quite a few pilot house builds on the HAMB.
[Re: kissmyaspen]
#1324915
10/30/12 11:21 PM
10/30/12 11:21 PM
Posts: 773 Crofton, Ky.
rattler
Crofton, Ky.
You may have seen my 57. It sets on the forward half of an 88 Dak frame and the rear half is shortened, narrowed and boxed 57. You can set the ride height by how far down over the frame that you set the body.
1957 Dodge truck, Snakeskin Green with a little stroker motor. 1964 Plymouth Savoy wagon ( my new project)
[Re: rattler]
#1324916
10/30/12 11:25 PM
10/30/12 11:25 PM
rattler
Crofton, Ky.
another
[Re: poorboy]
#1324920
11/04/12 11:59 PM
11/04/12 11:59 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
63.4 inches for the front track on the Merc/Vic
[Re: kissmyaspen]
#1324922
11/06/12 10:48 AM
11/06/12 10:48 AM
kissmyaspen
Newark,Ohio
hope to get a frame this weekend so i can start on this project soon.
[Re: kissmyaspen]
#1324923
11/06/12 08:59 PM
11/06/12 08:59 PM
moparpollack
Lil Herman
Lil Herman
85086
Good luck!
[Re: moparpollack]
#1324924
11/06/12 11:35 PM
11/06/12 11:35 PM
rattler
Crofton, Ky.
Let us know how things go. If you have any questions about your build, please ask. I will ofer any help that I can.
[Re: rattler]
#1324925
11/06/12 11:37 PM
11/06/12 11:37 PM
rattler
Crofton, Ky.
This is a pic of the 88 Dak frame connected to the narrowed and shortened 57 frame.
[Re: kissmyaspen]
#1324933
01/23/13 11:31 AM
01/23/13 11:31 AM
Posts: 1,179 Canada
demon
Canada
Nice frame! Those Dakota frames were made for shortening. And for the 48-60 Dodge trucks they have very similar engine placement. You can splice the Dakota floor and firewall right into the old cab. Or place the old cab on the new frame and move your cab mounts. You can also use the Dakota box floor and attach your stepside box sides. Dakotas are the ideal doner.
[Re: demon]
#1324934
01/23/13 04:19 PM
01/23/13 04:19 PM
kissmyaspen
Newark,Ohio
should be welded on friday... then its time to get the cab off the old frame and start fitting before the frame goes to get blasted.
