Jesel Belt Drive
#1324031
10/21/12 04:40 PM
10/21/12 04:40 PM
Posts: 912 London, England
mopar_mark
London, England
Jewel Belt drive - I have lost the woodruff key from my Jesel belt drive, I know it's 0.125" wide, not sure on other dimension, I thought it may of been 7/16" dia, but doesn't seem to be a common size.
Anyone know the size or where I might source one. Jegs list one,but doesn't give sizes, also, not available to ship till the end of the month.
Thanks,
Re: Jesel Belt Drive
[Re: skrews]
#1324033
10/21/12 05:33 PM
10/21/12 05:33 PM
mopar_mark
London, England
Get one from Jesel.
I would of done last week, as was in New Jersey.
If I knew the size, I'm sure I could get one here or one made
Anyway, All sorted now
[Re: mopar_mark]
#1324034
10/21/12 05:47 PM
10/21/12 05:47 PM
Posts: 449 Hampton,Va
QuickDart 502
Hampton,Va
Get one from Jesel.
Thanks [/quote sorry not trying to hi- Jack your thread but how do you remove the hub off the end of the camshaft.
[Re: QuickDart 502]
#1324035
10/21/12 06:41 PM
10/21/12 06:41 PM
mopar_mark
London, England
If your referring to the cam shaft belt drive gear, undo the Left hand bolt on the front, this will allow pulley to come away from the tapered shaft & keyway
[Re: mopar_mark]
#1324037
10/21/12 08:22 PM
10/21/12 08:22 PM
QuickDart 502
Hampton,Va
actually it's the tappered hub that holds the sprocket.
