Over heating and your need help! sorry kind of long! #132271
10/04/08 07:31 PM
10/04/08 07:31 PM
Southeastern Ohio
1st_charger Offline OP
Southeastern Ohio
Ok, so here is the situation this morning I got my car out (69 charger 383 auto) got to the end of the road about 70 yards from my house and it died like some one just turned of the key and would not restart! I found that the orange box had failed so I replaced it with a parts store box drove about 35 miles and noticed my temp was up alittle more than usual but only about 5 to 10 deg has been running at 180! didn't think much about it! 2 hrs later I got in it to come home and about 1/4 the way home I noticed the temp was creaping up and not cooling down with at speed air flow! I got it pulled over and the temp was at 240 and she was spitting out the over flow! I noticed that the top hose was hot and the top of the radiator was hot but the bottom of the radiator and bottom hose was cool! So I don't think I'm getting any water flow! the radiator is new and also recently checked and I'm running a clutch fan and shroud! I'm thinking its the water pump hoping to tear it apart tomorrow but thought I would ask for any other ideas! double checked the timing after it cooled back to 180 and its still were I set it 10 initial and 34 total at 2400rpm. Thanks for any help!!!
Re: Over heating and your need help! sorry kind of long! [Re: 1st_charger] #132272
10/04/08 07:47 PM
10/04/08 07:47 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
do you have a coil (some call it a spring) in the lower hose to prevent collapse? YOu might be sucking the lower hose shut under the pull of the water pump.....
Re: Over heating and your need help! sorry kind of long! [Re: Pacnorthcuda] #132273
10/04/08 07:55 PM
10/04/08 07:55 PM
Thermostat
Re: Over heating and your need help! sorry kind of long [Re: RapidRobert] #132274
10/04/08 08:17 PM
10/04/08 08:17 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Thermostat
possible but a stuck stat wouldn't be letting the coolant back out of the engine into the upper hose. Check for a collapst or collapsing lower hose or very common plugged radiator core so that the coolant flow through the radiator is very slow
Re: Over heating and your need help! sorry kind of long [Re: MoparforLife] #132275
10/04/08 08:24 PM
10/04/08 08:24 PM
I was thinking partially stuck.
Re: Over heating and your need help! sorry kind of long [Re: Pacnorthcuda] #132276
10/05/08 09:04 PM
10/05/08 09:04 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Thermostat, first thing to check. They're cheap and easy to replace.
Anecdote: Driving home from the airport after a week trip; 4 miles form home notice the temp ind in the upper middle of the range and heading North fast. PUlled over and checked the upper hose. Tight as tick and mucho hot. Engine didn't get preigniting hot but was on its way.
Waited 1/2 hr to cool down. Did this once more before making it home. Next AM have to go to work, so remove the vaunted Robertshaw 195 less-than-two-years-old and stuck in the old 180 one I (fortunately) hadn't discarded. started and ran fine; back to normal temps on the way to work.
PIcked a new thermostat at Carquest on the way home. "Tested" the Robertshaw in a pan of water and it seemed fine, but it surely was the cause of the overheating.
My $0.02
Re: Over heating and your need help! sorry kind of long [Re: DZJim] #132277
10/05/08 09:17 PM
10/05/08 09:17 PM
San Jose, California
DennisH Offline
Vacation
DennisH  Offline
Vacation
NAPA. Superstat. No hole-drilling. Never had a problem.
Re: Over heating and your need help! sorry kind of long [Re: DennisH ] #132278
10/05/08 11:53 PM
10/05/08 11:53 PM
DuPont, Washington
DZJim Offline
DZJim  Offline
DuPont, Washington
Stock MOPAR, Stant, Carquest, AC Delco...no hole-drilling; no holes! Never yet a problem...
Re: Over heating and your need help! sorry kind of long [Re: DZJim] #132279
10/06/08 07:49 AM
10/06/08 07:49 AM
Southeastern Ohio
Southeastern Ohio
well I found it to be the stat! I pulled the stat and it looks fine Mr gasket Hi flow havent checked it in water yet but will! reinstalled with no thermostat and drove home never went over 160 so I'll be putting in a new thermostat this week! OH and the Mr gasket Hi flow was put in a month ago! Thanks for all the help! I still dont fully understand why the upper hose was so hot and the bottom hose was cool with it being the thermostat! I would have thought it was the other way around??
Re: Over heating and your need help! sorry kind of long [Re: 1st_charger] #132280
10/06/08 12:47 PM
10/06/08 12:47 PM
MA.
P
plymguy Offline
plymguy  Offline
P
MA.
My '67 Fury did the same thing back in July. I purchased two 180 degree t stats, one for each of my Furys. I got them from Summitt Racing Equipment and they are made by Mildon. They are a high flow t stat and are designed to stay open if they fail thus elimanting the overheating headaches.
John
Re: Over heating and your need help! sorry kind of long [Re: 1st_charger] #132281
10/06/08 01:28 PM
10/06/08 01:28 PM
probably because it was opening enough to allow some hoy water into the top of the radiator and such a small amount that it could cool that little bit down completely- but not enough open to allow the engine to cool well.
