Re: 2003 Grand Caravan tire wear- bad what is causing this?
[Re: Daty Rogers]
#1322520
10/18/12 11:58 PM
10/18/12 11:58 PM
Posts: 1,377 Ohio
Todd
Ohio
Looks like a an alignment issue. Get a print out of the results. You should have .1 degrees positive camber and .10 degrees toe in. As for the brake shake get the rotors machined and check the run out on the hub flange.
[Re: Todd]
#1322521
10/19/12 08:09 AM
10/19/12 08:09 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I agree looks like bad alingment.When the struts are replaced you have to have either new adjustable bolts installed or grind out the piece thats made in the bolt hole to adjust them for camber.The shake when braking is bad rotors.Tire balance had nothing to do with it when braking only.Ive seen new rotors out of the box that were warped.That or someone over tightens the wheels and warps them.Thats why I either use torque sticks or my T wrench.Typically new rotors are so thin that there isnt enough meat to turn them before they hit discard or minimum machine.Ive had better luck in the last 30 years at the shop using the store brand rotors than the hi buck ones.Do you have a printout from the last alingment?Rocky
Chrysler Firepower
[Re: AARCONV]
#1322523
10/19/12 10:06 PM
10/19/12 10:06 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Is that both front tires wearing the same ? If both front tires are wearing the same on inner or outer edges then its a toe issue. If only one side is wearing (one front tire not both) then its a chamber issue. One other thing I would see is from not rotating the tires. Does she have the tires rotated on a normal schedule like every other oil change ? You have to remember the front tires take alot of the weight when stopping and turning. It will cause the front tires to wear on the outer edges much more then the rear and if you dont rotate the tires about every 5000 to 7500 miles it will cause the front tires to wear much more then the rear. And if you never rotate them the rear tires will last about twice as long. But as was stated get the alignment printout and you can post it on here. Ron
[Re: Scamp451]
#1322525
10/20/12 07:36 AM
10/20/12 07:36 AM
therocks
Niles , Ohio
Ron I forgot about tire rotation.Most people dont rotate them.I also read 4 racks.Man where are you getting them.Plus a lot of brakes.Ive found for the most part Quick Struts are the way to go.They can be installed in what 1/2 hour and everything is new.My wifes PT has 125 and only on the second set of brakes.She drives hard.My brother and nephew have Caravans and no way do they go thru that many tires or brakes.They both drive hard also and my brothers is usually loaded.As said cheap tires will also wear odd and fast.Rocky
Chrysler Firepower
[Re: AARCONV]
#1322526
10/20/12 09:34 AM
10/20/12 09:34 AM
Posts: 738 TN
'84 D150 Shorty
Pickup Man
Pickup Man
TN
you didn't mention lower ball joints or tie rods...or even a wheel bearing...bearings will give you a shake as you described..when you changed the struts in the front...did you change the top strut mounts also? is it just the outside of that one tire or both sides?
I would check wheel hubs for play...
[Re: '84 D150 Shorty]
#1322527
10/20/12 09:50 AM
10/20/12 09:50 AM
383man
Balt. Md
That is true but since it was aligned a few times they should (the shops that did the alignments) have checked all the front end parts before aligning it. But SHOULD is the big player here. Ron
#1322528
10/20/12 09:52 AM
10/20/12 09:52 AM
Posts: 1,377 Ohio
Todd
Ohio
Any reputable alignment shop would have found those issues even before hanging the heads. If I find any problems with worn parts like that it gets fixed before the alignment. I don't want it coming back if it does I get to do it for free.
[Re: 383man]
#1322530
10/20/12 08:16 PM
10/20/12 08:16 PM
Posts: 1,377 Ohio
Todd
Ohio
Thats basically what I was saying as I was in the same boat where we would be doing it for free if it came back and we missed worn front end parts when doing a front end alignment. Ron
You treed me by 2 minutes. I'm a slow typer.
[Re: Scamp451]
#1322531
10/21/12 09:17 AM
10/21/12 09:17 AM
Posts: 9,825 MI, usa
dvw
MI, usa
Pic
If your talking about cupping on the edges it has more to do with tread design than alignment. Assuming the alignment is correct. Cross rotating the tires from left to right so they rotate in the opposite direction is the ONLY cure. If done during normal intervals they will stay like new. If the cupping is already severe it will help but the damage has been done. Old theory suggested never to cross radials. This is not true with today's tires. I worked as a dealer tech for 27 years doing alignments. Doug
[Re: Scamp451]
#1322532
10/21/12 10:24 AM
10/21/12 10:24 AM
Posts: 2,177 ill
dennismopar73
ill
Pic
WOW,, bet that drives like a car on poly glass tires on a rain slick muddy country road!! You need some one else doing front end alignment and repairs!!! I have seen alot of 'so called' repairs done to cars that where never done ! What a shame, I have seen dealers tell a customer that had brought their van in 3 x over growling in the front end,, brakes wore plum into the rotor so bad you would not believe!!,, Then tell the customer , yeah we drove it and everything is fine! charge her $100 each time 'for nothing wrong' !! On the 4 try I took it in I all ready looked at it knew the issue, the service manager(yeah right), drove it, came back , said , " it needs new tires and shocks "! gave us a price,, on cost to repair @ $1000,, That's when I stepped up,, said , Look dum dum, it just need brakes,!! and now rotors!! He looked at me, said are you ASE certfied mechanic??, YES I AM !!! He goes , well you put on the pads and rotors , when that don't fix it, you come on back we will fix it!! Would not take a pedal car to a dealer!!
[Re: dennismopar73]
#1322533
10/21/12 01:24 PM
10/21/12 01:24 PM
therocks
Niles , Ohio
I cant believe the people that bring cars in for an alingnment because it has a shake in the front end.That and the ones that had bad parts that wanted an one done anyway.Id just tell them it wont fix a wobble.The ones with bad parts were told no also.Some really insisted.The Favorite saying was I know it needs TR or etc but do it anyway.I wont complain when its still bad.Politley told them either fix it or leave.Rocky
Chrysler Firepower
[Re: therocks]
#1322535
10/21/12 02:30 PM
10/21/12 02:30 PM
Posts: 1,377 Ohio
Todd
Ohio
I run into that all the time. I get the repair order and it says, customer states has vibration wants alignment checked. I then have to ask do you want the vibration fixed or just the alignment checked. I guess some people just don't understand.
