Hooking a 4 speed car...what do I need? #1322485
10/18/12 06:55 PM
10/18/12 06:55 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm trying to decide what suspension to complete out the rear of my car with.
I've currently got a set of really worn out HD springs on the back of my car that have settled to a near zero arch. I've also picked up a new set of XHD springs to replace them.
At the track I'll be running an ET Street DR or Conventional ET Street. At least a 10.5" tire.
The rest of the driveline will be a centerforce DF, 1350 DS and a 3.54 Powrlok Dana 60.
Will XHD leafs with the threaded style pinion snubber work for a 600rwhp car? Or are Cal-tracs needed? I've got Koni's and 1.24" torsion bars up front, so I really need to get to about 150/lb springs to get what I know is "matched".
I would like to imagine that well below a 2.0 60' could be done easily....
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Hooking a 4 speed car...what do I need? [Re: AlexP] #1322486
10/18/12 07:22 PM
10/18/12 07:22 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
I'm not an expert, but the Centerforce is a very grabby clutch and broke a ton of stuff in my Charger because I didn't know how to drive it easily. A lot of it was due to severe axle wrap, if I ever have another I would go the caltrac route for that reason alone. I don't know how well the caltracs would work with your new XHD springs though.
I've definitely heard from multiple sources, and experienced with my car, that stick cars do not like drag radials. You can get them to work, but they're very finicky, and with the rest of your setup (huge front T-bars, assuming stiff shocks, etc) I would go with conventional bias ply ET Streets for the track.
Re: Hooking a 4 speed car...what do I need? [Re: AlexP] #1322487
10/18/12 08:02 PM
10/18/12 08:02 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you should be able to pull 1.60's pretty easy w/ 600 rwhp. As mentioned 4 speeds are hard on parts. I'd think you could start w/ what you have and some drag shocks. I'm trying to get down to 1.55 and so far no luck. I might try and clamp the pass side spring next time out. I have XHD springs too w/ rear drag shocks and brand new MT radial Pros (275/60/15)
If I can't get it to 60 foot better I might try the cal-tracs. Right now I'm around 1.60-1.65
Coming soon!!!!
Re: Hooking a 4 speed car...what do I need? [Re: AlexP] #1322488
10/18/12 10:00 PM
10/18/12 10:00 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Not sure how your planning on driving the car off the line, but my first year with a 5 speed and slow mid 13 second car I had a pinion snubber (adjusted properly) and leaf springs with an extra leaf added to stiffen them up (very arched) and adjustable shocks and the car hopped like a lowrider on the launch dumping the clutch at around 3500-4000rpms...I can't imagine things getting any better with added power, and to be honest if super stock springs don't work (and im kinda thinking they won't) caltracs really are your best option. I'd get rid of those XHD's for a set of the calvert mono's and either look into caltrac bars or the smith racecraft assassin bars and good rear shocks. You will need good shocks and a good traction system to control the hit with the stick if you plan on leaving with any kind of power or aggressiveness (i.e. not riding out the clutch)
As for tires, you won't hook worth a damn with drag radials and a stick...I know from experience with this, even on slower cars, radials just don't like the dump of the clutch and tend to be very inconsistent. Use the conventional ET streets. Also, you don't seem to be short for power, but that is not enough gear to maximize the potential of the car (atleast in my opinion). I know you are building a hemi, but the powerband of the motor will dictate the gearing. Sticks like a higher numerical ratio, but you might be ok with what you have. Best is to try it and see- 60's might suck and it may not trap where you want, so a ratio change may be in order.
I have had good luck leaving at 5000rpms off a two step with a CF DF clutch, and I know of a couple of mustangs here running high tens with the same clutch at 3100-3200lbs race weight. They are a good clutch for what they are. I would try it and see how it works, although you may need an adjustable clutch.
I would take it out and see what it does. Make a pass, if things get out of line, stop before you break anything and then address the problems. Im no expert, but I ran the stick for the past three years at varying power levels (never at yours though) so I have learned a few things about what works and what doesn't.
Good luck man!
Re: Hooking a 4 speed car...what do I need? [Re: mshred] #1322489
10/18/12 11:11 PM
10/18/12 11:11 PM
MI
68shifter Offline
68shifter  Offline
MI
Are you going to be 100% strip car or just occasionally?
If your springs are completely shot I would replace them and clamp em. Also pick up a decent set of shocks with a decent stiff extension capability(Calvert 9 way, or other brands). Store more shock for extension than bump.
As Matt said don't waste your time with radials. Sidewalls are inconsistent and just a variable you can't control.
Try and get the front as loose and quick responding as possible with 4-5" of movement.
A CF DF clutch will be tight but a lot of people do use them with success. That motor will probably have a good amount of torque to help with the gearing though not ideal.
On the cal-tracs... Wouldn't spend my money. In my old setup with SS springs went 1.45-1.47 normally, added caltrac bars to the springs-very aggressive launch and no 60 or et change. Then changed over to the full caltrac setup, no change again, but was able to lower the back of the car. I eventually sold them.
Once you start making some passes let us know...I'll send your man card out right away
Andre
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: Hooking a 4 speed car...what do I need? [Re: AlexP] #1322490
10/18/12 11:12 PM
10/18/12 11:12 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
I think with the weight/power/and HP I kinda think that you don't want it to hook too much. Something has to slip or something will likely break. If the car is mainly drag race, then I would suggest getting smaller diameter torsion bars and get the front end loose (something I was not too successful in the belvedere). The drag radials tend to be binary (hook or slip with nothing in between). MT suggests that they NOT be used with stick cars. Also, 4.10 or 4.56 rear gears would take load off of the trans/clutch. The CF DF is a great clutch, but you do have to build in slip somewhere or you will likely smoke the clutch. I never tried SS springs/snubber and had used caltracs with XHD rear springs. In less than a season they become S shaped. The stock springs are much thicker than the monoleafs which affects the function of the caltracs. Also, if I recall the XHD springs have 6 leafs on the right side and 5 on the left (i.e. different thickness). This would make the caltracs act differently on each side.
If its mainly a street car to race every now and then, set it up for how you want it on the street, and then either add air to the slicks for slip or learn to slip the clutch some coming out. You can also be consistent with a 'controlled bog', just not as fast as it could be.
Good luck
It is fun
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: Hooking a 4 speed car...what do I need? [Re: oldiron] #1322491
10/19/12 03:21 AM
10/19/12 03:21 AM
sweden
sshemi Offline
sshemi  Offline
sweden
What tranny ratios?
I dont know about the xhd springs but my -68 abody v8 leafs cant take the hit even clamped.
My car got almost no paint left in the driveshaft tunnel.
Re: Hooking a 4 speed car...what do I need? [Re: sshemi] #1322492
10/19/12 03:25 AM
10/19/12 03:25 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Bare minimum run a snubber or things will grenade.
Mopar to the bone!!!
Re: Hooking a 4 speed car...what do I need? [Re: 68shifter] #1322493
10/19/12 04:20 AM
10/19/12 04:20 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Andre
69 GTX 68 Road Runner
Re: Hooking a 4 speed car...what do I need? [Re: JERICOGTX] #1322494
10/19/12 06:34 AM
10/19/12 06:34 AM
sweden
sshemi Offline
sshemi  Offline
sweden
I have decided to go with caltracs on mine but i dont know if i need their single leaf springs.
And now i am in the process of building a 833 with 3.09 first gear witch i think will help alot with the 60' compared to the 2.66 first.
I have 3.73 gears.
Re: Hooking a 4 speed car...what do I need? [Re: sshemi] #1322495
10/19/12 09:33 AM
10/19/12 09:33 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
not to hi-Jack this post but what is the best way to clamp the rear springs??? I have a clamp kit somewhere and like to try it.
Re: Hooking a 4 speed car...what do I need? [Re: Mr.Yuck] #1322496
10/19/12 05:53 PM
10/19/12 05:53 PM
Cincinnati Oh
fasthawk6 Offline
fasthawk6  Offline
Cincinnati Oh
I have the caltracs with new hd springs and will go a 1.60 60ft time.I have tried the mickey drag radials not with great results. Switched to the et streets and much better 27 10.50s.The caltracs really help with axle wrap.If i was to do it over i would.
Move the springs in 3/4 which i already did
make the rear shocks straight up in down which help control the rear of the car better.
Went to the big radial race in georgia and saw a neat setup for leaf springs. It used a front segment with the caltrac bar and a coilover setup to hold the rear of the car up, Seemed like that was the hot ticket.
Re: Hooking a 4 speed car...what do I need? [Re: AlexP] #1322497
10/19/12 07:49 PM
10/19/12 07:49 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have had just about every combo posted above and my current combo seems to work best with the 3800# SS springs,NO SNUBBER,Rancho 9 way adjustable shocks.
It hooks with slicks and slips with MT ET streets.I used Caltracs with mono-leafs and they worked very well but the springs wore out in one season of street/strip use.
I turn a 1.49 short time the my current shock/spring package
Gus
64 Plymouth Savoy
Dana 60
Re: Hooking a 4 speed car...what do I need? [Re: fourgearsavoy] #1322498
10/19/12 08:33 PM
10/19/12 08:33 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I too have tried most of the combos listed. My current set up has "A" body SS springs(002-003). I run Rancho 9 ways set on 9. NO SNUBBER. I also run the Centerforce "11" clutch assembly. A833 18 spline. From personal experience, SOMETHING has to slip, unless you plan on breaking parts. My car is set up to slip the slicks about 10 feet at launch. Radials with a stick car don't work. I run Hoosers (29" x12"). My 60' times are around 1.54-1.60, depending on track conditions, but my car is a street car that I take to the track sometimes. It's not an all out race car. Also, my car weighs 3726 without me in it. With my 200+ pounds, it's a load to get moving. My rear gears are 4.56 Dana's. Hope this helps you get pointed in the right direction.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Hooking a 4 speed car...what do I need? [Re: 68LAR] #1322499
10/19/12 09:45 PM
10/19/12 09:45 PM
cleveland Ohio
mloboda Offline
mloboda  Offline
cleveland Ohio
Larry, are using that new 19 spline 833 that Passon just came out with ?
Re: Hooking a 4 speed car...what do I need? [Re: mloboda] #1322500
10/20/12 04:08 AM
10/20/12 04:08 AM
sweden
sshemi Offline
sshemi  Offline
sweden
So you two are saying that ss springs is the way to go?
Thats like opposite of everyone else.
Doesnt the ss springs have bad quality nowadays?
Re: Hooking a 4 speed car...what do I need? [Re: mloboda] #1322501
10/20/12 12:03 PM
10/20/12 12:03 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
No Mike, I use a stock 18 spline "HEMI" trans. I had "fat fingers" and hit a "9" instead of an "8" and I didn't check my post for correctness. Sorry.
All I'm saying is "I" use SS springs and have for over 30 years. The springs that are on the car now are over 15 years old and they still have a slight arch to them. What "I" do over the winter months each and every year, is jack the car up and let the suspension "hang" over the winter. Torsion bars and rear springs both. I believe that this adds life to the bars and springs.
Re: Hooking a 4 speed car...what do I need? [Re: sshemi] #1322502
10/20/12 12:14 PM
10/20/12 12:14 PM
Rittman Ohio
Rittman Ohio
Probably not the "ultimate" drag only suspension but it does work for a street car that I like to race about a half dozen times a year.
If I were racing my car every weekend I would put the Cal-Tracs and mono-leafs back on again.I drive my car fully loaded with with camping gear food for the weekend and the full race rear suspension just wasn't cutting it for a dual purpose car.That being said my suspension works perfect on the track as well with adjustable shocks
Gus
64 Plymouth Savoy
Dana 60
Re: Hooking a 4 speed car...what do I need? [Re: fourgearsavoy] #1322503
10/21/12 08:10 AM
10/21/12 08:10 AM
sweden
sshemi Offline
sshemi  Offline
sweden
Gus
Thats exatly like mine, i drive to the track with all the gear in the trunk, but i dont like how high they seem to sit in the rear with ss springs.
But i dont feel like replacing caltracs springs each year either.
Any other suggestions before i buy anything i dont need or like?
Sorry to highjack...
Re: Hooking a 4 speed car...what do I need? [Re: sshemi] #1322504
10/21/12 10:18 AM
10/21/12 10:18 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Try one inch SOLID lower blocks. That's what I use. But don't use the hollow cast type. They will crack in half.
The picture of my car in my sig is how my car sits normally.
