Re: Hooking a 4 speed car...what do I need?
[Re: AlexP]
#1322486
10/18/12 07:22 PM
10/18/12 07:22 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
I'm not an expert, but the Centerforce is a very grabby clutch and broke a ton of stuff in my Charger because I didn't know how to drive it easily. A lot of it was due to severe axle wrap, if I ever have another I would go the caltrac route for that reason alone. I don't know how well the caltracs would work with your new XHD springs though.
I've definitely heard from multiple sources, and experienced with my car, that stick cars do not like drag radials. You can get them to work, but they're very finicky, and with the rest of your setup (huge front T-bars, assuming stiff shocks, etc) I would go with conventional bias ply ET Streets for the track.
[Re: AlexP]
#1322488
10/18/12 10:00 PM
10/18/12 10:00 PM
Posts: 3,425 Toronto
mshred
Toronto
I'm trying to decide what suspension to complete out the rear of my car with.
I've currently got a set of really worn out HD springs on the back of my car that have settled to a near zero arch. I've also picked up a new set of XHD springs to replace them.
At the track I'll be running an ET Street DR or Conventional ET Street. At least a 10.5" tire.
The rest of the driveline will be a centerforce DF, 1350 DS and a 3.54 Powrlok Dana 60.
Will XHD leafs with the threaded style pinion snubber work for a 600rwhp car? Or are Cal-tracs needed? I've got Koni's and 1.24" torsion bars up front, so I really need to get to about 150/lb springs to get what I know is "matched".
I would like to imagine that well below a 2.0 60' could be done easily....
Not sure how your planning on driving the car off the line, but my first year with a 5 speed and slow mid 13 second car I had a pinion snubber (adjusted properly) and leaf springs with an extra leaf added to stiffen them up (very arched) and adjustable shocks and the car hopped like a lowrider on the launch dumping the clutch at around 3500-4000rpms...I can't imagine things getting any better with added power, and to be honest if super stock springs don't work (and im kinda thinking they won't) caltracs really are your best option. I'd get rid of those XHD's for a set of the calvert mono's and either look into caltrac bars or the smith racecraft assassin bars and good rear shocks. You will need good shocks and a good traction system to control the hit with the stick if you plan on leaving with any kind of power or aggressiveness (i.e. not riding out the clutch)
As for tires, you won't hook worth a damn with drag radials and a stick...I know from experience with this, even on slower cars, radials just don't like the dump of the clutch and tend to be very inconsistent. Use the conventional ET streets. Also, you don't seem to be short for power, but that is not enough gear to maximize the potential of the car (atleast in my opinion). I know you are building a hemi, but the powerband of the motor will dictate the gearing. Sticks like a higher numerical ratio, but you might be ok with what you have. Best is to try it and see- 60's might suck and it may not trap where you want, so a ratio change may be in order.
I have had good luck leaving at 5000rpms off a two step with a CF DF clutch, and I know of a couple of mustangs here running high tens with the same clutch at 3100-3200lbs race weight. They are a good clutch for what they are. I would try it and see how it works, although you may need an adjustable clutch.
I would take it out and see what it does. Make a pass, if things get out of line, stop before you break anything and then address the problems. Im no expert, but I ran the stick for the past three years at varying power levels (never at yours though) so I have learned a few things about what works and what doesn't.
Good luck man!
[Re: mshred]
#1322489
10/18/12 11:11 PM
10/18/12 11:11 PM
Posts: 1,169 MI
68shifter
MI
Are you going to be 100% strip car or just occasionally? If your springs are completely shot I would replace them and clamp em. Also pick up a decent set of shocks with a decent stiff extension capability(Calvert 9 way, or other brands). Store more shock for extension than bump. As Matt said don't waste your time with radials. Sidewalls are inconsistent and just a variable you can't control. Try and get the front as loose and quick responding as possible with 4-5" of movement. A CF DF clutch will be tight but a lot of people do use them with success. That motor will probably have a good amount of torque to help with the gearing though not ideal. On the cal-tracs... Wouldn't spend my money. In my old setup with SS springs went 1.45-1.47 normally, added caltrac bars to the springs-very aggressive launch and no 60 or et change. Then changed over to the full caltrac setup, no change again, but was able to lower the back of the car. I eventually sold them. Once you start making some passes let us know...I'll send your man card out right away Andre
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: AlexP]
#1322490
10/18/12 11:12 PM
10/18/12 11:12 PM
Posts: 690 New Hampshire, USA
oldiron
New Hampshire, USA
I think with the weight/power/and HP I kinda think that you don't want it to hook too much. Something has to slip or something will likely break. If the car is mainly drag race, then I would suggest getting smaller diameter torsion bars and get the front end loose (something I was not too successful in the belvedere). The drag radials tend to be binary (hook or slip with nothing in between). MT suggests that they NOT be used with stick cars. Also, 4.10 or 4.56 rear gears would take load off of the trans/clutch. The CF DF is a great clutch, but you do have to build in slip somewhere or you will likely smoke the clutch. I never tried SS springs/snubber and had used caltracs with XHD rear springs. In less than a season they become S shaped. The stock springs are much thicker than the monoleafs which affects the function of the caltracs. Also, if I recall the XHD springs have 6 leafs on the right side and 5 on the left (i.e. different thickness). This would make the caltracs act differently on each side. If its mainly a street car to race every now and then, set it up for how you want it on the street, and then either add air to the slicks for slip or learn to slip the clutch some coming out. You can also be consistent with a 'controlled bog', just not as fast as it could be. Good luck It is fun
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge New New Best: 10.56 @129 68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up https://www.youtube.com/watch?v=T4jDLKwd9Gs
[Re: sshemi]
#1322492
10/19/12 03:25 AM
10/19/12 03:25 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Bare minimum run a snubber or things will grenade.
Mopar to the bone!!!
[Re: AlexP]
#1322497
10/19/12 07:49 PM
10/19/12 07:49 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have had just about every combo posted above and my current combo seems to work best with the 3800# SS springs,NO SNUBBER,Rancho 9 way adjustable shocks. It hooks with slicks and slips with MT ET streets.I used Caltracs with mono-leafs and they worked very well but the springs wore out in one season of street/strip use. I turn a 1.49 short time the my current shock/spring package Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1322498
10/19/12 08:33 PM
10/19/12 08:33 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: mloboda]
#1322501
10/20/12 12:03 PM
10/20/12 12:03 PM
68LAR
South Park, Pa.
Larry, are using that new 19 spline 833 that Passon just came out with ?
No Mike, I use a stock 18 spline "HEMI" trans. I had "fat fingers" and hit a "9" instead of an "8" and I didn't check my post for correctness. Sorry. Quote:
So you two are saying that ss springs is the way to go? Thats like opposite of everyone else. Doesnt the ss springs have bad quality nowadays?
All I'm saying is "I" use SS springs and have for over 30 years. The springs that are on the car now are over 15 years old and they still have a slight arch to them. What "I" do over the winter months each and every year, is jack the car up and let the suspension "hang" over the winter. Torsion bars and rear springs both. I believe that this adds life to the bars and springs.
[Re: fourgearsavoy]
#1322503
10/21/12 08:10 AM
10/21/12 08:10 AM
Posts: 2,128 sweden
sshemi
sweden
Probably not the "ultimate" drag only suspension but it does work for a street car that I like to race about a half dozen times a year. If I were racing my car every weekend I would put the Cal-Tracs and mono-leafs back on again.I drive my car fully loaded with with camping gear food for the weekend and the full race rear suspension just wasn't cutting it for a dual purpose car.That being said my suspension works perfect on the track as well with adjustable shocks Gus
Thats exatly like mine, i drive to the track with all the gear in the trunk, but i dont like how high they seem to sit in the rear with ss springs. But i dont feel like replacing caltracs springs each year either.
Any other suggestions before i buy anything i dont need or like? Sorry to highjack...
