Do I have to run a pcv #1322023
10/17/12 09:31 PM
10/17/12 09:31 PM
central P.A.
HEMIDOG 70 Offline OP
central P.A.
I have just started driving my Challenger. It has a 528 hemi. Right now I have a moroso breather with the nipple for a hose on each valve cover no hoses hooked up yet. Can I just t these breathers to the nipple on the air cleaner or is a pvc to the carb a must have? I have about 100 street miles on the engine and no issues I can see. The valve covers are the Barton Stage v cast covers.
Re: Do I have to run a pcv [Re: HEMIDOG 70] #1322024
10/17/12 09:42 PM
10/17/12 09:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
you don't "have to" but you ought to. Helps keep the engine clean, inside and out.
Don't be the exception.
Re: Do I have to run a pcv [Re: Supercuda] #1322025
10/17/12 11:48 PM
10/17/12 11:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Re: Do I have to run a pcv [Re: JohnRR] #1322026
10/18/12 12:11 AM
10/18/12 12:11 AM
70duster340 Offline
70duster340  Offline
When I first bought my Duster, the previous owner had just a breather installed on the valve covers of the 340. It had a constant oil film on the valve cover. It will help keep the engine clean.
Re: Do I have to run a pcv [Re: HEMIDOG 70] #1322027
10/18/12 06:44 AM
10/18/12 06:44 AM
places
79powerwagon Offline
places
Why would you not run a PCV?
Re: Do I have to run a pcv [Re: 79powerwagon] #1322028
10/18/12 07:08 AM
10/18/12 07:08 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 built 440 runs just 2 breathers.My kids 62 300 413 with 50K OE miles runs 2 also.Neither has any problems with pressure or oil film.Mine runs an M1 intake with Dominator and has no provisions for vacuum.When we put the headers on the 300 it eliminated the draft tube.Both have run like that for over 10 years.Rocky
Chrysler Firepower
Re: Do I have to run a pcv [Re: therocks] #1322029
10/18/12 10:07 AM
10/18/12 10:07 AM
wisconsin
1BAD68 Offline
1BAD68  Offline
wisconsin
Mine has a PCV on one cover and a breather on the other, is this right?
Re: Do I have to run a pcv [Re: 1BAD68] #1322030
10/18/12 12:08 PM
10/18/12 12:08 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes
Re: Do I have to run a pcv [Re: therocks] #1322031
10/18/12 12:13 PM
10/18/12 12:13 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
same here on my 496,if i beat on it real hard i will get a little oil seepage from the dipstick.
Re: Do I have to run a pcv [Re: bonefish] #1322032
10/18/12 12:20 PM
10/18/12 12:20 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Without a PVC valve, you are putting more pressure on the seals. Do you want oil leaks? Why not run one? Because you don't understand what they do?
Re: Do I have to run a pcv [Re: HEMIDOG 70] #1322033
10/18/12 12:43 PM
10/18/12 12:43 PM
Idaho
LaRoy Engines Offline
Idaho
The pcv is an emissions device that routes the oil vapors, produced by the engines internals, into your cylinders to be burned. Push all the oil into the cylinders that you want, it is however a very low octane fuel.
Re: Do I have to run a pcv [Re: HEMIDOG 70] #1322034
10/18/12 02:11 PM
10/18/12 02:11 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Back in the day, before there were PCV valves, there were road draft tubes to relieve pressure build up. These were cut on an angle and when you were driving created a low pressure stream that would remove the vapors and the built up pressure.
Re: Do I have to run a pcv [Re: az426john] #1322035
10/18/12 02:30 PM
10/18/12 02:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Similar to evac tubes in headers ?
Where would one have been on a big block , or smallblock for that matter , Chrysler ? I remember seeing one on the 56 Chevy I owned with a 6 banger ...
I can see not using a PCV on a race engine , street engine I would think it wouldn't really hurt ...
Re: Do I have to run a pcv [Re: JohnRR] #1322036
10/18/12 03:49 PM
10/18/12 03:49 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
BBs were on the pass side valve cover.I had quite a few.My kids was in the same place.He runs 2 K&N screen breathers and I run 2 Moroso breathers.Neither leaks.His 300 probally got more street miles in a year than most cars here get in 10.My 440 is pretty much a race motor driven on the street.Ive driven it quite a bit and no problems.Besides Im not goimg to drill a new intake just to install a PCV.Its sees 6 to 7 K revs regularly.Rocky
Chrysler Firepower
Re: Do I have to run a pcv [Re: HEMIDOG 70] #1322037
10/18/12 04:11 PM
10/18/12 04:11 PM
I run two PCV ,one in each valve cover, in my 518 C.I. pump gas stroker motor. I used a vacume T off the back of the intake that I drilled and tapped for a pipe thread and used a brass pipe nipple to hook the vacume hose to the T to I also run two breather caps, one in each cover. The PCV helps suck any condensation out of the motor once it gets up to temps as well as sucking any blowby fumes into the intake manifold, much better to burn them rascals up than to let them sit in the motor and cause acids mixing the water and oil together Besides adding the PCV opens up some more control vaume leaks, making the motor idle better with big cams
Re: Do I have to run a pcv [Re: Cab_Burge] #1322038
10/18/12 06:58 PM
10/18/12 06:58 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Do you have to re-jet the carb when you add a PCV valve? Or is the amount of air drawn into the the intake at idle so low it is a non-factor? What about at open throttle?
Re: Do I have to run a pcv [Re: Ramrod39] #1322039
10/18/12 07:08 PM
10/18/12 07:08 PM
dogdays Offline
dogdays  Offline
Generally the PCV is closed at idle, the high vacuum sucks it closed. Then at some point as vacuum drops, it opens up.
Now I'm not saying that there's no leakage, but if the PCV is stuck open it's hard to get a car to idle.
And yes, technically the oil vapors lower the octane rating of the mixture. It seems however, that the benefit of running a little vacuum or at least no positive pressure in the crankcase has more benefit.
My Poly 318 was leaking oil from every gasket. I found the hose to the PCV valve was collapsed internally. Replacing the hose cured 90% of the oil leaks.
R.
Re: Do I have to run a pcv [Re: dogdays] #1322040
10/18/12 07:23 PM
10/18/12 07:23 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Is a generic Auto Zone PCV valve OK? Brand recommendations?
What kind of hose?
Re: Do I have to run a pcv [Re: dogdays] #1322041
10/18/12 10:51 PM
10/18/12 10:51 PM
R.
You have the PCV operation theory backwards, it is open at high vacume and the spring inside closes it at WOT or when the motor is not running, if it is hook up correctly If you hook it up backwards it will work backwards
Re: Do I have to run a pcv [Re: Cab_Burge] #1322042
10/19/12 01:03 AM
10/19/12 01:03 AM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
Cab - I think you have the vacuum/valve open/valve closed thing bass-ackwards....
