Re: Do I have to run a pcv
[Re: HEMIDOG 70]
#1322024
10/17/12 09:42 PM
10/17/12 09:42 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
you don't "have to" but you ought to. Helps keep the engine clean, inside and out.
[Re: Supercuda]
#1322025
10/17/12 11:48 PM
10/17/12 11:48 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
[Re: 79powerwagon]
#1322028
10/18/12 07:08 AM
10/18/12 07:08 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
My 65 built 440 runs just 2 breathers.My kids 62 300 413 with 50K OE miles runs 2 also.Neither has any problems with pressure or oil film.Mine runs an M1 intake with Dominator and has no provisions for vacuum.When we put the headers on the 300 it eliminated the draft tube.Both have run like that for over 10 years.Rocky
Chrysler Firepower
[Re: 1BAD68]
#1322030
10/18/12 12:08 PM
10/18/12 12:08 PM
JohnRR
U.S.S.A.
Mine has a PCV on one cover and a breather on the other, is this right?
yes
[Re: therocks]
#1322031
10/18/12 12:13 PM
10/18/12 12:13 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
same here on my 496,if i beat on it real hard i will get a little oil seepage from the dipstick.
[Re: bonefish]
#1322032
10/18/12 12:20 PM
10/18/12 12:20 PM
Challenger 1
Cincinnati, Ohio
Without a PVC valve, you are putting more pressure on the seals. Do you want oil leaks? Why not run one? Because you don't understand what they do?
[Re: az426john]
#1322035
10/18/12 02:30 PM
10/18/12 02:30 PM
JohnRR
U.S.S.A.
Back in the day, before there were PCV valves, there were road draft tubes to relieve pressure build up. These were cut on an angle and when you were driving created a low pressure stream that would remove the vapors and the built up pressure.
Similar to evac tubes in headers ?
Where would one have been on a big block , or smallblock for that matter , Chrysler ? I remember seeing one on the 56 Chevy I owned with a 6 banger ...
I can see not using a PCV on a race engine , street engine I would think it wouldn't really hurt ...
[Re: JohnRR]
#1322036
10/18/12 03:49 PM
10/18/12 03:49 PM
therocks
Niles , Ohio
BBs were on the pass side valve cover.I had quite a few.My kids was in the same place.He runs 2 K&N screen breathers and I run 2 Moroso breathers.Neither leaks.His 300 probally got more street miles in a year than most cars here get in 10.My 440 is pretty much a race motor driven on the street.Ive driven it quite a bit and no problems.Besides Im not goimg to drill a new intake just to install a PCV.Its sees 6 to 7 K revs regularly.Rocky
Chrysler Firepower
[Re: dogdays]
#1322041
10/18/12 10:51 PM
10/18/12 10:51 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Generally the PCV is closed at idle, the high vacuum sucks it closed. Then at some point as vacuum drops, it opens up. Now I'm not saying that there's no leakage, but if the PCV is stuck open it's hard to get a car to idle. And yes, technically the oil vapors lower the octane rating of the mixture. It seems however, that the benefit of running a little vacuum or at least no positive pressure in the crankcase has more benefit.
My Poly 318 was leaking oil from every gasket. I found the hose to the PCV valve was collapsed internally. Replacing the hose cured 90% of the oil leaks. R.
You have the PCV operation theory backwards, it is open at high vacume and the spring inside closes it at WOT or when the motor is not running, if it is hook up correctly If you hook it up backwards it will work backwards
