MLS Head Gasket - Better for NON-Torque-Plate Hone? #1321882
10/17/12 03:15 PM
10/17/12 03:15 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
Long story short: When my 452 was re-honed, it was NOT done w/ a torque plate. Therefore, would using an MLS head gasket instead of a composition-type head gasket (i.e. Fel-Pro) result in less bore distortion when the heads are installed?
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: BradH] #1321883
10/17/12 03:26 PM
10/17/12 03:26 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
No...Not bolting the heads to the block will result in less bore distortion....Bolt a torque plate down to the block and torque it, and at least check it! If outs out a bunch, re-hone it.
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: Dragula] #1321884
10/17/12 03:30 PM
10/17/12 03:30 PM
Washington
skrews Offline
skrews  Offline
Washington
x2
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: skrews] #1321885
10/17/12 03:47 PM
10/17/12 03:47 PM
BradH Offline OP
BradH  Offline OP
x2
"Long story short" means I'm not going into the history of why this block was re-honed w/o the plate. If it wasn't done then, it's not going to happen now that I'm already reassembling the bottom end.
The "new build in progress" 451 on the engine stand a few feet from the 452 has been "done right" in that respect and will be the long-term replacement.
I'm simply looking for a way to minimize the bore distortion issue as I put the 452 back together as the interim solution to get the Challenger running again.
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: BradH] #1321886
10/17/12 03:57 PM
10/17/12 03:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its still going to distort the same, so no those gaskets
wont change anything
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: BradH] #1321887
10/17/12 03:59 PM
10/17/12 03:59 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Heads will be torqued the same with ether gasket. Since the fasteners do the majority of the distortion I would say take your pick.
Getting old just means you were smarter than some and luckier than others.
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: dannysbee] #1321888
10/17/12 04:40 PM
10/17/12 04:40 PM
BradH Offline OP
BradH  Offline OP
OK, let me re-phrase my question after having done some additional research on my own...
First, here are links to various articles that specifically mention how MLS head gaskets do actually reduce bore distortion because they distribute the clamping loads better than a composite gasket:
http://www.circletrack.com/enginetech/ctrp_1108_racing_head_gaskets/viewall.html
www.aera.org/ep/downloads/ep11/EP07-2010_42-48.pdf
http://www.popularhotrodding.com/enginem...ng/viewall.html
http://www.popularhotrodding.com/enginem...g/photo_13.html
http://www.popularhotrodding.com/enginem...g/photo_14.html
So, I suppose what I should ask is, given that I already own the correct style of composite head gaskets for my 452, would the additional expense of buying MLS gaskets be justified because they should reduce some of the bore distortion resulting from my block having been re-honed w/o a torque plate?
Maybe this is just a pure judgement call, but I was hoping to get some input re: whether this thought makes sense to anyone else.
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: BradH] #1321889
10/17/12 05:28 PM
10/17/12 05:28 PM
Renton Washington
Triple Threat Offline
Renton Washington
Blocks and heads using MLS gaskets are machined/ surfaced with a smoother finish than normal for sealing reasons. If this hasn't been done I would KISS and put it together with the composite gaskets.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: Triple Threat] #1321890
10/18/12 10:15 AM
10/18/12 10:15 AM
BradH Offline OP
BradH  Offline OP
I believe the block & heads surfaces are already smooth enough to use MLS gaskets, so I'm still considering the option. Just not sure if there would really be a benefit for the additional expense.
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: BradH] #1321891
10/18/12 10:46 AM
10/18/12 10:46 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Seems to me that every time someone gives you a sensible reply you come up with another reason to use the MLS gaskets. So I'd suggest you make yourself happy and go ahead and use them.
Re: MLS Head Gasket - Better for NON-Torque-Plate Hone? [Re: Stanton] #1321892
10/18/12 10:57 AM
10/18/12 10:57 AM
BradH Offline OP
BradH  Offline OP
In many cases, a "sensible reply" is simply PLR (Path of Least Resistance). I'm trying to determine if there is a legit benefit to the idea, rather than just throwing on what I have on hand.
The first replies said it wouldn't make a difference, but I found out elsewhere that it could. So now I'm still wondering if it will make enough of a difference to bother with.
What makes me happy is knowing that I've made a good decision based on the knowledge I have available at the time.
