Re: MLS Head Gasket - Better for NON-Torque-Plate Hone?
[Re: Dragula]
#1321884
10/17/12 03:30 PM
10/17/12 03:30 PM
Posts: 429 Washington
skrews
Washington
No...Not bolting the heads to the block will result in less bore distortion....Bolt a torque plate down to the block and torque it, and at least check it! If outs out a bunch, re-hone it.
x2
[Re: skrews]
#1321885
10/17/12 03:47 PM
10/17/12 03:47 PM
BradH
x2
"Long story short" means I'm not going into the history of why this block was re-honed w/o the plate. If it wasn't done then, it's not going to happen now that I'm already reassembling the bottom end.
The "new build in progress" 451 on the engine stand a few feet from the 452 has been "done right" in that respect and will be the long-term replacement.
I'm simply looking for a way to minimize the bore distortion issue as I put the 452 back together as the interim solution to get the Challenger running again.
[Re: BradH]
#1321887
10/17/12 03:59 PM
10/17/12 03:59 PM
Posts: 5,160 Texas
dannysbee
Texas
Heads will be torqued the same with ether gasket. Since the fasteners do the majority of the distortion I would say take your pick.
Getting old just means you were smarter than some and luckier than others.
[Re: Stanton]
#1321892
10/18/12 10:57 AM
10/18/12 10:57 AM
BradH
Seems to me that every time someone gives you a sensible reply you come up with another reason to use the MLS gaskets. So I'd suggest you make yourself happy and go ahead and use them.
In many cases, a "sensible reply" is simply PLR (Path of Least Resistance). I'm trying to determine if there is a legit benefit to the idea, rather than just throwing on what I have on hand.
The first replies said it wouldn't make a difference, but I found out elsewhere that it could. So now I'm still wondering if it will make enough of a difference to bother with.
What makes me happy is knowing that I've made a good decision based on the knowledge I have available at the time.
