Busted the U joint again
#132179
10/04/08 04:22 PM
10/04/08 04:22 PM
Posts: 20 Minnesota
FROZEN BOHEMIAN
Minnesota
This is the 2nd time I have broken the saddles that hold the U-joint to the pinion yoke. I had a spare set of saddles but now they are broke too. Where can I find some of these for my 1965 Barracuda 7 1/4" rear end. What else fits? any 7 1/4" rear end?
Re: Busted the U joint again
[Re: FROZEN BOHEMIAN]
#132181
10/04/08 04:41 PM
10/04/08 04:41 PM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Summit has them as does Advance NAPA etc.Summit carries MP ones.Rocky
Chrysler Firepower
[Re: txterry2]
#132182
10/04/08 04:51 PM
10/04/08 04:51 PM
Posts: 20 Minnesota
FROZEN BOHEMIAN
Minnesota
Maybe,it's trying to tell you to go bigger.
yeah ..or stop power braking it in the driveway!!!'same thing my wife said....
#132183
10/04/08 08:31 PM
10/04/08 08:31 PM
RapidRobert
balance that shaft EDIT more thoughts, flange could be out of round(not likely) ujoint angle way off(not likely). Overtorquing the small bolts. any 7&1/4 straps will work for you & I believe any 7260 flanged rear will have what you need.
[Re: RapidRobert]
#132184
10/05/08 10:35 AM
10/05/08 10:35 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
power braking and blowing that out might blow the sprag in the trannie?
Is it a slant?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: Rug_Trucker]
#132185
10/05/08 05:35 PM
10/05/08 05:35 PM
Posts: 20 Minnesota
FROZEN BOHEMIAN
Minnesota
OK so I found some U Joint Clamps at the local NAPA but now that it is all back together it dont look right to me............ It was the only clamps they had in stock and no listing for 65 Barracuda. I am waiting for AUTOZONE to get some in they had a listing for this application. Comments???
#132187
10/05/08 08:22 PM
10/05/08 08:22 PM
Posts: 1,043 Slidell, La.
doctor_mopar
Slidell, La.
Those are the wrong ones ! Those you bought are for the large 7290 joint. You need the ones for the smaller 7260 joint. zYou may also have the bolts cocked or damaged.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
#132188
10/05/08 08:45 PM
10/05/08 08:45 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
How many joints have you gone through?
I bet its time for a new yoke.
If the yoke isnt true, youll never keep joints in it.
DAMHIK
Doc.
