Busted the U joint again #132179
10/04/08 04:22 PM
10/04/08 04:22 PM
Minnesota
FROZEN BOHEMIAN Offline OP
Minnesota
This is the 2nd time I have broken the saddles that hold the U-joint to the pinion yoke. I had a spare set of saddles but now they are broke too.
Where can I find some of these for my 1965 Barracuda 7 1/4" rear end.
What else fits? any 7 1/4" rear end?
Re: Busted the U joint again [Re: FROZEN BOHEMIAN] #132180
10/04/08 04:40 PM
10/04/08 04:40 PM
fort worth,tx
txterry2 Offline
super gas
txterry2  Offline
super gas
fort worth,tx
Maybe,it's trying to tell you to go bigger.
Re: Busted the U joint again [Re: FROZEN BOHEMIAN] #132181
10/04/08 04:41 PM
10/04/08 04:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Summit has them as does Advance NAPA etc.Summit carries MP ones.Rocky
Chrysler Firepower
Re: Busted the U joint again [Re: txterry2] #132182
10/04/08 04:51 PM
10/04/08 04:51 PM
Minnesota
Minnesota
yeah ..or stop power braking it in the driveway!!!'same thing my wife said....
Re: Busted the U joint again [Re: FROZEN BOHEMIAN] #132183
10/04/08 08:31 PM
10/04/08 08:31 PM
balance that shaft EDIT more thoughts, flange could be out of round(not likely) ujoint angle way off(not likely). Overtorquing the small bolts. any 7&1/4 straps will work for you & I believe any 7260 flanged rear will have what you need.
Re: Busted the U joint again [Re: RapidRobert] #132184
10/05/08 10:35 AM
10/05/08 10:35 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
power braking and blowing that out might blow the sprag in the trannie?
Is it a slant?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Busted the U joint again [Re: Rug_Trucker] #132185
10/05/08 05:35 PM
10/05/08 05:35 PM
Minnesota
Minnesota
OK so I found some U Joint Clamps at the local NAPA but now that it is all back together it dont look right to me............ It was the only clamps they had in stock and no listing for 65 Barracuda.
I am waiting for AUTOZONE to get some in they had a listing for this application.
Comments???
Re: Busted the U joint again [Re: FROZEN BOHEMIAN] #132186
10/05/08 06:11 PM
10/05/08 06:11 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Looking at the one failed saddle, it looks like the saddle might be hitting something, and one of the bolts looks like it might be stripped.
The new saddles are incorrect and you need to get the ones that fit properly.
Re: Busted the U joint again [Re: FROZEN BOHEMIAN] #132187
10/05/08 08:22 PM
10/05/08 08:22 PM
Slidell, La.
doctor_mopar Offline
Slidell, La.
Those are the wrong ones ! Those you bought are for the large 7290 joint. You need the ones for the smaller 7260 joint. zYou may also have the bolts cocked or damaged.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
Re: Busted the U joint again [Re: FROZEN BOHEMIAN] #132188
10/05/08 08:45 PM
10/05/08 08:45 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
How many joints have you gone through?
I bet its time for a new yoke.
If the yoke isnt true, youll never keep joints in it.
DAMHIK
Doc.
