Drag slick questions #1321797
10/17/12 12:38 PM
10/17/12 12:38 PM
Harrisburg Pa. 17112
moparmikethree Offline OP
Who makes the best drag slicks, also good street cheaters
What air pressure do you use, and do you spin balance slicks?
Re: Drag slick questions [Re: moparmikethree] #1321798
10/17/12 12:52 PM
10/17/12 12:52 PM
Locomotion Online content
Locomotion  Online Content
I've had excellent results from Hoosier slicks. I only run their lightweight radial slicks because I normally run on very well prepared tracks. They are a little faster, but sensitive to track conditions/prep. But for most applications, I would recommend their regular, bias ply slicks. They are less sensitive to marginal track conditions and will be more consistent. Consistency is what wins bracket races.
Air pressure will vary with every combination. Using wider wheels can allow the use of higher air pressure while still maintaining a full "footprint", reduce sidewall flex and help stability on the top end. I have 9" slicks on 10" wheels and have been running 21 lbs in them. But you would need to experiment to see whats best for your combo.
Post some car info as well as tire and wheel sizes you are considering and someone may have a similar set-up that can offer a starting point for air pressure.
Hoosier also has a variety of sticky DOT street tires.
Hoosier drag tires
Re: Drag slick questions [Re: moparmikethree] #1321799
10/17/12 02:04 PM
10/17/12 02:04 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Those are ambiguous questions either you want drag slicks (radial or biased), drag radials or biased street strip tires?
or both slicks and streets strip
Do you have a 1400 lb T bucket or a 4000 lb Charger
you have 7 in rims or 22 inch monsters
400 hp or 1500 hp
Tire pressures can be 5 lb to 25 lb there is a lot of variables
I like Phoenix slicks.
Got goodyears now I like Phoenix slicks
Re: Drag slick questions [Re: Locomotion] #1321800
10/17/12 03:44 PM
10/17/12 03:44 PM
I was just trying to get a general ideal. this is a 70 Challenger
727 trans about 3400lbs, aprox 450 flywheel hp. This weekend was my first time out ever (Drag Racing). I got the RT to a .032 on a .000
light. 60' was 2.2 with spin, thats why I asked about a good tire, weather a slick or a Cheater (dot)
Re: Drag slick questions [Re: moparmikethree] #1321801
10/17/12 04:05 PM
10/17/12 04:05 PM
Avondale AZ
Prodart440 Offline
Prodart440  Offline
Avondale AZ
I have a 71 cuda, and I am running the M&H Streetmaster DOT slicks. My best 60' so far is 1.88, but I am only running mid 12's.
Aaron
68 Roadrunner 383/AT
69 Dart GT Conv. 383/AT
05 Dodge Ram 4x4 Cummins
06 GoManGo R/T Daytona #757
68 Coronet 440
Re: Drag slick questions [Re: moparmikethree] #1321802
10/17/12 04:22 PM
10/17/12 04:22 PM
rear gears are 3:23.
later i found i never got in 3rd gear.
ran 98.8mph 14.04 et
No tach in car shifted by sound, kick down is adjusted wronk
when full throttle trans does not go into third.
Re: Drag slick questions [Re: moparmikethree] #1321803
10/17/12 04:39 PM
10/17/12 04:39 PM
SHELBY TWP,,MICHIGAN
72N96RR Offline
I LOVE WEDGIES
72N96RR  Offline
I LOVE WEDGIES
You need to be much more specific... its different for everyone and every car...
1972 Road Runner / GTX 440 4spd Dana 3.54 Just about to turn 26K original miles..
A boat, a GMC truck, some Craftsman Tools, LOTS of Zombie Protection, and a few Goldfish..
If you love someone set them free..
If they come back it means nobody else wanted them either..!!
Re: Drag slick questions [Re: 72N96RR] #1321804
10/17/12 05:34 PM
10/17/12 05:34 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
What are the other racers at your local track useing? Theres probally a reason why there are more of 1 brand slick that other brands.
I am truckless..
