2000 Durango - cruise control rpm fluctuations #1321519
10/16/12 09:54 PM
10/16/12 09:54 PM
NC
DCM71cuda Offline OP
NC
My parents have a 2000 Durango, 5.9 engine.
When you set the cruise control, it maintains speed, but the rpm varies constantly; as if the throttle is continuously being applied and released. What could the problem be? Maybe a vac. leak somewhere? Any help appreciated
Re: 2000 Durango - cruise control rpm fluctuations [Re: DCM71cuda] #1321520
10/16/12 10:17 PM
10/16/12 10:17 PM
Texas
Daty Rogers Offline
World's Greatest Husband. I love you Robyn
Daty Rogers  Offline
Texas
My ex's did the same thing. Never did figure out why.
-Daty
Re: 2000 Durango - cruise control rpm fluctuations [Re: Daty Rogers] #1321521
10/16/12 11:03 PM
10/16/12 11:03 PM
IN
ahy Offline
ahy  Offline
IN
Does it sort of act like it is about to kick down then doesen't? It is likley the throttle position sensor failing. Its a fairly common problem and pretty easy to repair. My 1'st gen Durango had the same problem, mostly with cruise set. A new TPS cleared it up.
Re: 2000 Durango - cruise control rpm fluctuations [Re: ahy] #1321522
10/16/12 11:09 PM
10/16/12 11:09 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My 2000 R/T did the same thing when I first got it. It kinda acted like the lockup was releasing then reapplying. Tach would move a couple hundred RPM. TPS was the problem.
Re: 2000 Durango - cruise control rpm fluctuations [Re: slantzilla] #1321523
10/16/12 11:23 PM
10/16/12 11:23 PM
NC
NC
That is kinda what it seems like. May have to try replacing that.
Re: 2000 Durango - cruise control rpm fluctuations [Re: DCM71cuda] #1321524
10/16/12 11:38 PM
10/16/12 11:38 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
Sister's '04 Jeep GC did the same thing for a long time. TC would go in and out of lockup also, with associated jump in rpms. TPS finally got so bad that it threw a code. Apparently, there's some threshold value of failure it has to exceed before it throws a code. TPS was pretty cheap at RockAuto.com. $28 or so, IIRC. New TPS fixed it.
Re: 2000 Durango - cruise control rpm fluctuations [Re: MoparMarq] #1321525
10/17/12 01:40 AM
10/17/12 01:40 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Some years also had a PCM flash to help with that. Ron
Re: 2000 Durango - cruise control rpm fluctuations [Re: 383man] #1321526
10/17/12 08:31 AM
10/17/12 08:31 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If the RPM is fluctuating without the vehicle speed actually changing, then it sounds like either it's shifting in and out of OD, or the TC is locking/unlocking.
the PCM is programmed to lock/unlock the TC whenever you lift on the throttle, so if the TPS is bad like the other suggested, then the computer is struggling to see what the throttle is doing, so it's locking/unlocking the torque converter, which is what's giving you the RPM fluctuations.
**Photobucket sucks**
Re: 2000 Durango - cruise control rpm fluctuations [Re: 70Cuda383] #1321527
10/17/12 02:04 PM
10/17/12 02:04 PM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
TPS should take care of that, if TC is coming in and out and you have to set CC every time ck stop lite switch. TPS also cause idle fluctuation of 50-100 rpm.
Re: 2000 Durango - cruise control rpm fluctuations [Re: SALEM1912] #1321528
10/17/12 02:30 PM
10/17/12 02:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
When mine was doing it I even took it to a Dodge dealer and asked them if it could be the TPS. I was told no, and they'd never seen another one doing it.
I perused the Dakota-Durango board for about 3 minutes and found out it is a very well known issues with Gen III Dakota/Durangos.
My buddy even had a V-6 Gen III doing it.
Re: 2000 Durango - cruise control rpm fluctuations [Re: slantzilla] #1321529
10/18/12 05:19 PM
10/18/12 05:19 PM
NC
NC
We changed the TPS and that fixed it.
Thanks for the help.
