70 Roadrunner door int. paint question. #1320682
10/15/12 12:41 AM
10/15/12 12:41 AM
still waiting on 684
K
Kiner Offline OP
Kiner  Offline OP
K
Black interior. What color black and finish ? On the doors.
single stage ? 2k ? clear ?
Thanks.
Re: 70 Roadrunner door int. paint question. [Re: Kiner] #1320683
10/15/12 10:04 AM
10/15/12 10:04 AM
SE Pa.
LimeliteAero Offline
SE Pa.
the original paint code is X9 but theres a lot of wiggle room there, dont use clear. Just a good single stage black enamel.
Re: 70 Roadrunner door int. paint question. [Re: LimeliteAero] #1320684
10/15/12 09:36 PM
10/15/12 09:36 PM
K
Kiner Offline OP
Kiner  Offline OP
K
Thanks. What finish? semi, gloss?
Re: 70 Roadrunner door int. paint question. [Re: Kiner] #1320685
10/15/12 09:57 PM
10/15/12 09:57 PM
Calgary, Alberta Canada
a12rag Online content
a12rag  Online Content
Pretty sure it should be gloss . . .that is what I have (and originally had) on my 70 Sport Satellite.
Cheers
Mark
Re: 70 Roadrunner door int. paint question. [Re: a12rag] #1320686
10/16/12 01:46 AM
10/16/12 01:46 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Factory parts were gloss, but didnt have a mirror finish..
I used PPG Concept black on mine.
Re: 70 Roadrunner door int. paint question. [Re: sthemi] #1320687
10/17/12 02:49 PM
10/17/12 02:49 PM
SE Pa.
SE Pa.
Thats a good suggestion....does anyone have any other opinions?
Re: 70 Roadrunner door int. paint question. [Re: LimeliteAero] #1320688
10/17/12 04:02 PM
10/17/12 04:02 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
If you use base/clear, just add 10-15% clear matte to the clearcoat. It just depends on what brand paint you use for the mixing ratio. Same goes for single stage paint. Also, this is where the cheaper brand paints come into use, being a lower quality, giving it a factory look, if it is applied right.
Re: 70 Roadrunner door int. paint question. [Re: 70_FJ6_RR] #1320689
10/17/12 08:15 PM
10/17/12 08:15 PM
K
Kiner Offline OP
Kiner  Offline OP
K
Thank you for the responses. Any other suggestions?
Re: 70 Roadrunner door int. paint question. [Re: Kiner] #1320690
10/18/12 03:57 PM
10/18/12 03:57 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
I just went to the local paint shop...they pulled the color sheet and sold me a pint of paint with reducer and hardner.... PPG...
$150.... ouch...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: 70 Roadrunner door int. paint question. [Re: JMCFAN] #1320691
10/19/12 01:15 PM
10/19/12 01:15 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I tried using the white interior color, didn't like it so I tried the satin black. Didn't like it either and decided to use the body color, (Sublime). It looks great but its not correct.
...FAFO...
