How to remove brake pedal pushrod from mastercylinder? #131994
10/04/08 12:51 PM
10/04/08 12:51 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Can the brake pedal master cylinder push rod be removed from the master cyliner, in this case from a '68 road runner mc? Thanks.
MikeR
Re: How to remove brake pedal pushrod from mastercylinder? [Re: A12] #131995
10/04/08 01:04 PM
10/04/08 01:04 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Mike,there is a rubber insert in the back of the piston, it seems to swell up around the pushrod making a very tight fit. I had to put the master cylinder in a vice, vice grips on the pushrod, then hit the vice grips with a hammer to knock the pushrod out.
Re: How to remove brake pedal pushrod from mastercylinder? [Re: Dave Watt] #131996
10/04/08 01:26 PM
10/04/08 01:26 PM
Cincinnati, OH
6T6Cuda Offline
6T6Cuda  Offline
Cincinnati, OH
What I do if I dont care about the car (more then not the case for you...),
1. Unbolt the MC
2. Put a pickle fork over the rod and around pressing against the firewall
3. Use the brake pedal as a slide hammer to pull it out.
This usually works and does not pull the MC piston out (another danger) when pulling on it.
But be careful of the firewall...
All my cars are unrestored and rough so this works for me...
Re: How to remove brake pedal pushrod from mastercylinder? [Re: 6T6Cuda] #131997
10/04/08 04:48 PM
10/04/08 04:48 PM
N.E. OHIO, USA
A12 Offline OP
A12  Offline OP
N.E. OHIO, USA
Thanks guys, I talked to 1350cfm and he convinced me I needed a bigger hammer I had the master cylinder off of the car and thought it might have a wire clip but it turned out to be the rubber "square-ring" as you said. I clamped the pushrod in a vice and seeing it was an old master cylinder tried at first with a plastic mallet but no go and that's when I thought I should ask if it does come out. When Mike assured me that it does come out "I got a bigger hammer" Also the next time I'm going to soak it with some silicone or soapy liquid so I don't tear the sharp edge....like I did. The square ring measures 1/2"-od, 1/4"-id and 1/4"-wide if anyone wants to know and the local auto parts doesn't have one Thanks again.
MikeR
Re: How to remove brake pedal pushrod from mastercylinder? [Re: A12] #131998
10/04/08 07:50 PM
10/04/08 07:50 PM
iowa
copchaser Offline
copchaser  Offline
iowa
Wedge the master cylinder in a fixed object and hook the push rod to a D-9 cat and take off, this always works for me. Just besure the fixed object is truely fixed. If all else fails, drink Grain Belt beer.
Re: How to remove brake pedal pushrod from mastercylinder? [Re: A12] #131999
10/04/08 08:53 PM
10/04/08 08:53 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
MikeR
Those can be a bear to remove...
This method has worked for me, however it is only recommended for taking the rod out of a cylinder that you plan to junk, because the aluminum piston may not survive. Take the piston out with the rod. Heat the rod. Dont go crazy, just enough to soften the o ring up. Back the piston up in the vise and put a long 3/8 extension perpendicular in the circular end that attaches to the pedal. Give it a good pull with both hands and you are done.
Re: How to remove brake pedal pushrod from mastercylinder? [Re: A12] #132000
10/04/08 09:41 PM
10/04/08 09:41 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I get mine from Moparts member gregZ
Re: How to remove brake pedal pushrod from mastercylinder? [Re: Lefty] #132001
10/04/08 10:16 PM
10/04/08 10:16 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
If you can find a master cylinder rebuild kit, I think it comes with a new pushrod retainer?
Re: How to remove brake pedal pushrod from mastercylinder? [Re: RoadRunnerJD] #132002
10/04/08 10:37 PM
10/04/08 10:37 PM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
Yes it does.
Re: How to remove brake pedal pushrod from mastercylinder? [Re: Dave Watt] #132003
10/04/08 10:51 PM
10/04/08 10:51 PM
Warrenton, VA
Warrenton, VA
I've never seen a pushrod retainer sold separately? I wonder if there's a p/n for one?
Re: How to remove brake pedal pushrod from mastercylinder? [Re: Lefty] #132004
10/05/08 08:22 AM
10/05/08 08:22 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Same here,and since the price is so right,I ordered 6 of 'em just to have in the parts bin.
Nautilus Racing-
Re: How to remove brake pedal pushrod from mastercylinder? [Re: RoadRunnerJD] #132005
10/05/08 10:15 AM
10/05/08 10:15 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
think 1/4" vacuum line a pair of scissors
Re: How to remove brake pedal pushrod from mastercylinder? [Re: gtx6970] #132006
10/15/08 05:13 PM
10/15/08 05:13 PM
Think "wondering why you listened to poor advice and your vintage mopar is now totalled and your feeling glad no one died in the accident" There is NO vacuum hose in existance that I could find that was the correct durometer, outside diameter or inside diameter. Sorry, vacuum hose has it's place, but not as a major safety componant.
We're talking about brakes here people, not washer solvent squiters.
