test stand, empty 727 trans case question #1319902
10/13/12 09:51 PM
10/13/12 09:51 PM
central Florida
titan Offline OP
titan  Offline OP
central Florida
guy's, will a empty 727 Trans. case locate the starter in the proper location to work with a manual trans. flywheel for a engine run-on stand?Thanks
Re: test stand, empty 727 trans case question [Re: titan] #1319903
10/13/12 10:23 PM
10/13/12 10:23 PM
okla.
sam64 Offline
sam64  Offline
okla.
it should the starters are all the same.i am using a power glide adapter flywheel on mine.
Re: test stand, empty 727 trans case question [Re: sam64] #1319904
10/14/12 12:04 AM
10/14/12 12:04 AM
St. John's Newfoundland
440newport Offline
440newport  Offline
If it's a 130 tooth flywheel it should work since 727 torque convertors also have a 130 tooth ring gear I believe.
Re: test stand, empty 727 trans case question [Re: 440newport] #1319905
10/14/12 12:29 AM
10/14/12 12:29 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
No problem. For guys that don't have an empty case or bellhousing, I made a small adapter plate that holds the starter, which is what I used on mine and have been thinking about selling them. The usual 10-tooth starters work with 130 & 143 tooth flywheels/convertors according to my FSM.
