Re: r3-w9 finaly
[Re: jg309]
#1318873
10/11/12 02:56 PM
10/11/12 02:56 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
finaly got to make a dino pull after 6mths. re-doing stoufe, made 728hp @ rear wheels 1st pull, great power curve, this was @ 7800rpm,later jg309
Dude, that is stout Now, what is the specs. on the motor and apllication, street, street and strip, strip only or?
Re: r3-w9 finaly
[Re: jg309]
#1318876
10/11/12 04:10 PM
10/11/12 04:10 PM
Posts: 3,456 Out West
408strokerdart
Out West
900 crank hp? Not sure I saw the build on here. How big is it and who did the power parts (heads, cam design, intake)? One carb or two?
Nice power.
Re: r3-w9 finaly
[Re: onyxba]
#1318878
10/11/12 05:31 PM
10/11/12 05:31 PM
Posts: 288 IL. Jerseyville
jg309
IL. Jerseyville
thanks bryan,haven't heard back that was just the 1st pull,it's a 364ci,ryan done the heads,it was the intake patteren for kents 520 intake,hughs roller cam,2.18 titaum intakes/1.65 titaum ex., 1.75 jessel roller rockers, single (WILLY'S)4150 carb, this is a ump dirt modifed,its a 3.335 stroke, a beatuful wineberg with crowler 6.125 rods, & flat top pistons, i think 4.180 bore, its been a real changle,heads we were told were 15* got al the parts for that * & when we went to sub assy nothing fit, had to cut the pistion notchs,make spacer plates for the intake,re-drill the rocker stands, & elongate the head bolt holes & when we did this got into both intake chambers, & rick liuizzo told us hold to fix them, if you read this rick, thanks again,just a nice pice, jg309,still looking for someone in the st.louis area to put jessel key-ways in
8
